Scratch that . I didnt realze it was easier to move it in the control SW, thought you had to move it on control panel. I did notice that Z will move while Neg Z is held down, but X&Y still only work as pulses. Can you adjust that?
Cant find a reference to moving the X&Y remotely or by hand(unpowered) and I need to clean or check the final mirror & lens. & Can you set the z table to move in continuous mode instead of pulses? TIA Dubliner
My Z axis was the opposite - it could only be moved in steps but the step length could be set.
