Results 1 to 5 of 5
Thread: Epilog Zing C02 laser and comparable
    Dec 2006
    Hello everyone. I'm in the market for a laser engraving and cutting machine. I recently took a look at the Epilog C02 system. Very nice machine. Will do everything I need for around $8k. Are there any other machines that are comparable in the area of system capabilites, support, warranty, that I should be looking at?
    I'll be engraving, wood, several different polymers, and marking uncoated aluminum with the Cermark process. Would like to look at several before I pull the trigger on one. Any suggestions? Thanks.
    Rob
    Dec 2008
    The ULS entry level machine VLS2.30 is about $6-8k depending on options, I think it's pretty close in capability (not sure about the table travel).
    If you go with a US vendor of the Chinese systems (someone like Ray at Rabbit Laser - USA) you get personal service and support and potentially save thousands.
    Zax.
    Registered Tweakie's Avatar
    Nov 2009
    UK
    From reports I have read and examples of work I have seen pictures of I would also suggest that Ray Scott and Rabbit deserves really serious consideration.
    Tweakie.
    CNC is only limited by our imagination.
    Oct 2010
    I would give our vote to Dean from legacylasers.com
    His support has been great and the machine he sold us has a 2 year warranty
    Aug 2009
    Las Vegas
    Google Full Spectrum Laser 40w and find our webpage for USA designed controllers and software.
    RetinaEngrave is print driver based like Epilog and Universal. You can compare our prices.
    If you really want a Chinese software system, beware of the following:
    The cheap chinese systems come with Moshisoft, NewlySeal or NewlyDraw.
    The good chinese systems come LaserCut 5.3.
    If you want LaserCut 5.3 on your laser, we will sell you the same machine for less money and still give you USA based support.
    LaserCut 5.3 relies on plugins which need to be rewritten each new revision of software.
    Try getting it to work on Autocad 2011 or CorelDraw X5.
    Print driver systems work on practically all software, past, present and future.
    1. Laser Cutter Universal VS Epilog
      By inertialabs in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-05-2013, 01:13 PM
    2. Newbie- free cnc plans for a 50 watt epilog laser cutter
      By beverageexpert in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 09-25-2010, 10:41 PM
    3. EPILOG LASER 36 EXT CUTTER and ENGRAVER 120 WATT CO2
      By aussie_laser in forum EBAY ADS
      Last Post: 03-07-2010, 07:22 PM
    4. Epilog Summit EX Laser Engraver 25 watt
      By aussie_mick in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-01-2010, 09:40 PM
    5. Which Epilog laser?
      By m-134b in forum Engraving Machines
      Last Post: 01-06-2010, 09:53 PM
