Results 1 to 11 of 11
Thread: A few ?'s about Lasercut 5.3
    Jul 2006
    1 - Can it be converted or is it available in Imperial units
    2 - In the power/speed window, is that mm per second?
    3 - I believe it wont work in Corel X4, will the driver work in X3 but on a vista or Win 7 machine?
    Registered luckydoglele's Avatar
    Aug 2009
    china
    i can answer your first question till now, the first one , it can change into Imperial units
    , i am sure, i will ask tomorrow for you.
    second i it is yes
    third i donot know , by the way , i can comfirm tomorrow, so see you tomorrow.
    lele
    Registered oneeye's Avatar
    Aug 2005
    brazil
    Quote Originally Posted by Dubliner View Post
    1- Yes u can change to imperial
    2_ yes it can be installed in corel X$, i use it in x4
    3_ yes is mm/seg. ( i realy canīt understand how someone could create a meassure like inch.... and worse, how can someone use it! )
    Jul 2006
    ...perhaps I should also have said "How can it be changed to Imperial?"
    Jul 2006
    apparently its possible, but it must be a secret...
    Sep 2008
    It's been a long time since I was reading about it and I do not use Lasercut, but I seem to recall it is in the Configuration file in the same folder as the program. The same file that contains the password.
    Dave
    Registered kewlkiwi's Avatar
    Oct 2004
    New Zealand
    Metric v Imperial
    'Just had a look in 'laser.ini' in my Lasercut 5.0 folder.
    The only likely-looking item I can see is a line that reads:
    [CoordSystem_0]
    (There are several CoordSystem lines, with various postcripts, in the .ini files)
    Remember, if you make any changes to the .ini files - it's good idea to make a back-up copy first!
    Feb 2005
    I have LC 5.0 also and I don't use (didn't like) the Corel plug-in for this version. With a Corel file that is in inches, I "save as" an AI 7 file and then import that into LC and it cuts the correct imperial size, minus beam width of course.
    I know that's an extra step but I've never had any problem with it not cutting the correct sizes. I've never tried to use LC as a drawing program, so the metric measurements aren't a problem. All my cut files come from Corel in imperial measurements and that's what the results are.
    Skip
    Jul 2009
    I always made all my arts and cut on corel draw, separating the cuts with one color and the engravings with another color, when the art is finish I EXPORT the art as an Autocad DXF file.
    On LaserCut I just use the import feature and look for the DXF file and walla.
    Aug 2007
    Did anyone figure out how to switch to imperial?? I would like to do this as well.
    Necessity is the mother of all invention (unknown)
    My club home page www.lhmac.org
    Oct 2010
    Quote Originally Posted by oneeye View Post
    I like metric, the problem is in the USA it's hard to find measuring instruments in metric. Especially precision ones, like micrometers and calipers. And try to find a tape measure in metric, seriously!!!
    P.S. I would also like to know how to convert it to imperial.
    1. LaserCut 5.0
      By edsawen in forum LaserCut
      Last Post: 08-21-2012, 10:08 AM
    2. Need LaserCut 5.0
      By ArturoV in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 12-19-2009, 02:26 AM
    3. Lasercut V51 - HELP!
      By TheWorkshopGuy in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 10-05-2009, 06:25 AM
    4. Need Help!- lasercut
      By LOLO80 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 04-11-2009, 08:56 AM
    5. Lasercut 5.3 (5.2)
      By bibi in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-17-2009, 10:42 PM
