Results 1 to 6 of 6
Thread: The dynamics of raster engraving
    Dec 2005
    I would like to know which scenario is used by the controller . Suppose the laser head is sweeping across and comes to the end of the drawing. There is a certain time - distance where the head comes to a stop and changes directions. Also the gantry moves to a new position during this time. When does the controller tell the gantry to move?
    1. does it start moving as soon as the last dot is done and the head is still in motion?
    2.Does it move as soon as the head comes to a stop and then both axis accelerate from a stop
    3. Does it move as soon as the head comes to a stop and the head waits until the carriage moves before it accelerates?
    Hope this makes sense
    Registered Tweakie's Avatar
    Nov 2009
    UK
    Hi AustinT,
    I think I understand what you mean here.
    In my case this is all taken care of by the trajectory planner part of the control system. As the X axis nears the end of it's travel it's speed starts to decrease (deceleration) and the planner starts to reduce the available laser power level to match the reducing speed ending with zero speed and zero laser power level. Then the Y axis is incremented for the next line. The planner then increases laser power as speed is increased (acceleration) at the start of the next line until max speed and max available laser power is achieved. And so on.......
    I presume most planners work this same way.
    Tweakie.
    CNC is only limited by our imagination.
    Dec 2005
    Thank you for the reply, This is probably a little deeper than I need to think about it right now but I find it fascinating.
    Thanks again!
    Dec 2008
    Quote Originally Posted by Tweakie View Post
    Tweakie.
    Tweakie, would you mind refreshing my memory - what control system are you using?
    Zax.
    Nov 2009
    UK
    Hi Zax,
    I was referring to the operation of the Impact Engraver / Laser plugin as part of Mach3 using the Tempest trajectory planner.
    This is the only system I have studied in detail but as laser cutting depth and speed are so closely related I am assuming that all systems must reduce the available laser power at the beginning and end of raster scan lines otherwise they would cut deeper as the axis slows.
    Tweakie.
    Dec 2008
    Thanks Tweakie. That was the answer I was looking for 'Mach3 laser plug in'.
    Zax.
    1. Newbie- raster xy and yx in Lazycam
      By pistolknight in forum Mach Software (ArtSoft software)
      Last Post: 12-14-2008, 05:52 PM
    2. Smart Raster
      By zoltan in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-11-2008, 01:53 AM
    3. Raster to vector
      By lez in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 01-06-2007, 11:54 PM
    4. Raster To Vector (R2V)
      By tknief in forum CNCzone Club House
      Last Post: 09-28-2006, 11:46 AM
    5. raster to vector
      By teilhardo in forum General CAM Discussion
      Last Post: 05-05-2004, 09:56 AM
