Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: newlydraw engraving problem with rabbit laser 40A
    Jul 2010
    france
    hi guys
    I have a Rabbit 4OA
    with newlydraw
    when I import DFX files (made with inkscape)
    the file seems ok when displayed in newlydraw, the lines are perfect
    but when i engrave, the drawing is not well alined
    the parallel lines, are no more parallel...etc
    the drawing is scrambled
    however when I test an engravin by creating a file directly in newlydraw (texte or squares...etc) or when I engrave a BMP or a JPG, all seems ok
    does any one know why the DFX lines are corrupted when engraved (but well displayed in the newlydraw screen)
    many thanks
    Jul 2010
    france
    any help is wellcommed
    Dec 2008
    Since you can output vector and raster ok the problem must be the dxf file.
    The points are probably not close enough to 'join' correctly or there is some other fault with the dxf. In Newlydraw these errors may only show up when you view using a fill mode, which requires 'scan' mode.
    You can send me an example dxf if you like (zax15uk at mail.com) and I can help determine the corrective actions.
    Zax.
    Jul 2010
    france
    Quote Originally Posted by zax15uk View Post
    Zax.
    Hi Zax
    I've just sent you two dfx files
    perfect when displayed on inkscape or newlydraw, but corrupted when engraved.
    thanks
    Dec 2008
    I will take a look.
    Zax.
    Dec 2008
    Your dxf files look ok to me, but I will reply to your email with the versions I used so you can test them.
    If they still produce incorrect output perhaps you could take a photo and post so I can compare.
    Zax.
    Jul 2010
    france
    Zax.
    ok, Thanks
    Jun 2008
    Finland
    I've had some similar problems, but those was solved with saving the works to .ai and/or .plt-format. But my software is LaserCut, so I don't know if it's possible to import those formats to Newlydraw...!?
    Anyway, I hope you can get your problem fixed !
    Regards, Hannu
    Dec 2008
    In my experience Newlydraw works great with dxf files.
    I think there may be something else wrong here.
    Zax.
    Jul 2010
    france
    Zax.
    thanks Zax for your files
    Am going to try them
    and keep you informed
    Jul 2010
    france
    Hi again
    I tried your files
    had the same problem
    one wen correct (not perfect) but when I rescaled It (smaller) all went wrong
    here are two pictures (one of my engraving, the other of the file opened in Inkscape, I've sent you by email)
    I thought it was because I resized the file in newlydraw, so I resized it instead in Inkscape
    but had the same problem
    one more thing
    I have this problem only in "cut" mode
    all is correct in scan mode
    I'm completely disapointed
    Attached Thumbnails Attached Thumbnails newlydraw engraving problem with rabbit laser 40A-vie_screen.jpg   newlydraw engraving problem with rabbit laser 40A-vie_screen-grave.jpg
    Jul 2010
    france
    WAW
    just after posting my previous message
    I thought about some thing
    I restaured my windows XP to a previous date (one month earlier)
    because by this time I havent such problems
    when the restauration finished, I tried once again my files
    and MIRACLE!! all went OK
    so:
    make sure you have a restauration point when your soft&machine work correctly
    because windows is a **** OS sometimes
    even if my laptop I use for engraving is only used to "engrave" (I do my creations on another one) and even if I have installed nothing else but newlydraw and windows XP, some times things go wrong.....
    many thanks for all
    to the Admins, perhaps others have the same problem
    please have them know about my findings
  • Page 1 of 2 12 LastLast
    1. need help with dc-k40 laser and newlydraw software
      By realmommasboy in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 02-17-2013, 03:06 PM
    2. Problem with my laser engraving cutting machine JZDQ-9060E type
      By almamy in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 01-15-2013, 10:37 PM
    3. Newbie- Problem with Newlydraw Software
      By froggygeorge in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 05-28-2010, 01:27 PM
    4. Need Help!- laser engraving problem
      By fish09 in forum Engraving Machines
      Last Post: 02-03-2010, 08:02 PM
    5. get rid of Newlydraw, new Mach3 Controlled 40W/50W/60W CO2 Laser Cutters and upgrades
      By fullspeceng in forum Product and Manufacturer Announcements
      Last Post: 11-15-2009, 09:53 PM
