Results 1 to 4 of 4
Thread: Power Levels between Lasers of different Sizes?
    Feb 2010
    Basically:
    If someone with a 45W machine running at 100% is cutting at a specific feed rate, and I have a 100W machine, is 45W of my machine equal to that one?
    That is, if I had the same focus mirror, etc?
    I'm trying to cut acrylic and having a heck of a time getting clean cuts but putting the same material in that other machine, it gets clean cuts. Where as I get either a mess, or not through it. Both are using air, no nitrogen.
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    What is type of your laser - glass or RF?
    Feb 2010
    C02, Glass & mirrors. (smoke & mirrors, it's like.. magic! ;-)
    http://17500mph.com/photos-3?g2_itemId=1851
    Forgot to mention that ...
    Jul 2008
    Lithuania
    On chinese glass tubes there is a lot of instantly changing parameters, affecting tube power in certain moment. So you can't compare this two tubes (45Wt at 100% power and 100Wt at 45% of power) as result each time will be different.
  1. Build Thread- BCC Support levels
    By DIFF OVER in forum BobCad-Cam
    Last Post: 02-13-2011, 05:15 AM
  2. X4 Levels
    By thebowman in forum Mastercam
    Last Post: 11-18-2009, 08:37 PM
  3. Newbie- creating levels
    By wheelieking71 in forum Mastercam
    Last Post: 05-14-2009, 11:14 PM
  4. masterCAM levels
    By awjareme in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-08-2007, 12:58 PM
  5. Levels
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 04-21-2004, 12:31 PM
