Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Laser Marking on Steel
    Jan 2006
    I am considering a laser marking/engraving machine.
    The material to be marked is Flat Steel with fine abrasive blasted surface.
    The maximum size to be marked is 2" x 1" on flat surface.
    The marking should be similar to the marking on the shanks of end mills, twist drills or saw blades.
    A variety of machines are available and the price of USA suppliers are 3 to 5 times the price from China for similar power.
    I would like to hear from any one having experience on metal marking regarding the suitable laser type, power requirement and USA vs China machine.
    R. Rossey
    Dec 2008
    It sounds like a task for a Yb:YAG laser. Higher output power will result in higher marking speeds, in most cases but there is a limit. 20W fiber is probably the lowest you would want to consider.
    What systems are you looking at? (links)
    Zax.
    Jan 2006
    From various specifications and capabilities, I narrowed down on YAG laser with 50 W power.
    75W and 100 W lasers I presume are increasing the depth of etch and widening the laser spot but not increasing the marking speed.
    Nothing is finalized yet.
    Rossey
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    Rossey, if not a secret, what is your budget and where are you looking for laser - USA/Europe or China?
    Dec 2008
    50W Nd or Yb YAG will provide excellent marking speed.
    Higher power diodes allow increased depth OR speed up to a point but do not necessarily result in a larger spot size. They also increase the cost!
    Zax.
    Sep 2010
    China
    Quote Originally Posted by rrossey View Post
    R. Rossey
    Hi Rossey,
    You can confirm one thing that YAG laser machine(laser wave length 1064nm) is the correct choice.
    For material,is that stainless steel or carbon steel?The marking will be different on two kinds of steel.
    1)Marking on Stainless steel:the color of the words will be black or white,and have color difference.The marking depth is not very clear.
    2)Marking on carbon steel:the marking depth is a little clear,there is no color difference.
    What is the size of your workpiece?
    Do you have request for the marking speed?
    If you make a decision to buy it from China,pls dont hesitate to send the e-mail to me!Let's discuss more details and help you to choose the proper machine
    Attached with some of our laser processing samples for your reference.
    YOYO
    Good quality and service!
    E-mail:gosunlaseryoyo@gmail.com
    http:www.gosunlaser.com
    Jan 2006
    Hi Litografa
    Are you a supplier of lasert machines?
    If yes, please give the specifications and capabilities of the machine to meet the marking requirements mentioned.
    What are the positive features of the machine and advantage for me to buy from you?
    It will be good to know the price or quote privately.
    From this point we can proceed to discuss on the specifications and requirements, if the information looks good.
    Rossey
    Jan 2006
    Hi Yoyo,
    Can not open the web site.
    The material is Carbon Steel.
    Component size varies, Consider 2" x 6" as the Max.
    You can email the machine description and quote at :
    rrossey45@yahoo.com
    Rossey
    Jul 2008
    Lithuania
    No, I am not supplier NOW
    I sell Chinese NDYAG lasers few years before, but my experience show me that better buy reliable US/Europe/Russian made equipment and work 5-10 years without hassle, than pay less from beginning for Chinese and spend thousands of dollars to keep them working
    Sep 2010
    China
    Hi Yoyo,
    rrossey45@yahoo.com
    Rossey
    Hi Rossey,
    I dont know why you cannt open web site,i can open it...
    Anyway,i have sent the details of my machine to your email box.
    Pls check it!
    Any questions,pls feel free to contact me!
    YOYO
    Http:www.gosunlaser.com
    Sep 2010
    China
    Our semiconductor side laser marking machine can mark steel and other metal material very well. There are 50W and 75W of laser power with Length of laser wave:1064nm , Marking scope: 100x100mm - 300x300mm, Min line width: 0.015mm, min character: 0.15mm, Marker line speed: ≤ 7000mm/s, Mark deepness: ≤0.4mm, Repeat precision: ±0.001mm, Power supply: AC220V 50Hz/, Operating temperature: 10-35°c, moisture: 5-75°c, Cooling style: closed loop water cooling, Demension: 1300mm*850mm*1160mm . If you're looking for purchase ,please feel free to contact me directly at kelvinguo@syfos.com
    Apr 2012
    How Can Laser Marking on Steel Laser Marking on Steel can be done
  • Page 1 of 2 12 LastLast
    1. Anybody know what a laser marking machine costs?
      By squale in forum General Metal Working Machines
      Last Post: 08-28-2011, 11:37 PM
    2. Marking Stainless using CO2 laser 60 Watt
      By Huahahahahaha in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-05-2010, 09:10 PM
    3. Laser Marking Clear Anodized Al
      By petriej in forum Engraving Machines
      Last Post: 10-04-2010, 07:16 PM
    4. Best laser for marking stainless steel, brass, etc.
      By art2009 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 09-21-2010, 03:39 AM
    5. Marking and drilling steel precisely
      By FandZ in forum General Metalwork Discussion
      Last Post: 12-23-2008, 09:21 AM
