I would budget $1k if using a glass tube, although you may be able to shop around and get all the components for ~$600.
The XY table design is slightly different between laser and CNC, since the laser can be built with much lower mass resulting in faster acceleration. Lasers do not require ballscrews or even leadscrews, belt drive is often acceptable. Of course if you already have an XY table there is no reason a laser retrofit could not be successful, but you may not get the optimum cutting speeds which will be required with balsa to prevent burning.
Zax.
LinkBack URL
About LinkBacks
