Right. Hopefully i can post this here o.o
My Rabbit 3040 finally gave up the ghost. the controllerboard went completely.
As such would like it to go to a good home if possible.
I've tried to convert it to run a rockcliff 4 axis controller. With this it works perfectly motor wise.
I just don't have the time to invest in rewiring the machine to take the controller.
It's just had a new 40w tube in february. Laser PSU is good as is the main PSU.
Motors run well using the rockcliff driver and mach 3.
Have not tested the ability for the driverboard to switch the laser but it should be possible as the PSU will take high or low TTL signals.
Laser does fire properly.
Am asking £900 with the controller, old board and cables/Software/Dongle and a decent (but worn) extract fan
Have a better watercooling setup for it also, going at £150. It's a PC watercooling box, Has internal pump, fan and twin radiators. helps keep the machine that little bit cooler. Full aluminium body. Nice and quiet and keeps the temperature down better than the bucket and pond pump they were supplied with.
Pickup only from derbyshire, UK
