Results 1 to 2 of 2
Thread: power, speed and material thickness
    Nov 2009
    Russia
    Question power, speed and material thickness
    Maybe someone could help - can't find such informations
    Just bought laser cutter (from China of cause) with 100W laser tube
    It can cut 2mm plastic sheet at speed 50mm/s and power 30% (10mV).
    I suppose if I make power 100% (30mV) - I can cut at 150mm/s, but there is only slight difference. (as I know - speed/power is linear dependence)
    Maybe it's because of laser tube?
    What is signs of deterioration of laser tube?
    Lifetime of the tube will be the same in case of 100% or 30% power?
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    Congratulation! Put here pictures of your laser.
    If you use tube on 100% it will work MUCH shorter time than on 30%.
    Is optical path alligned well? How long this tube worked? If delivery was by sea - how many days it took? Packaging was done well or not (rust on metal parts exist or not)
  1. Pines Numbers 3&4 Benders Frame Thickness and Nose Thickness
    By morribi in forum Bending, Forging,Extrusion...
    Last Post: 02-03-2010, 10:59 PM
  2. Thickness of RC car and truck body material.
    By Robot Dude in forum Vacuum forming, Thermoforming Etc
    Last Post: 12-22-2009, 10:48 AM
  3. Material thickness chart?
    By voltsandbolts in forum DIY CNC Router Table Machines
    Last Post: 12-15-2008, 11:42 AM
  4. Need Help!- Working with stock thickness material.
    By svatchi in forum Work Fixtures and Hold-Down Solutions
    Last Post: 03-29-2008, 09:36 AM
  5. on Gildemeister speed 12 -7 hard material machining
    By Ashu in forum Hard and High Speed Machining
    Last Post: 10-16-2006, 08:14 AM
