Results 1 to 4 of 4
Thread: Protective shielding tape
    Jun 2007
    I need to protect the surface from laser cutting effects. Using masking tape gets old quickly when cutting bigger pieces.
    What suggestions do you have for both industrial and for locally available protection film that comes in a wide roll. For example, I am thinking about trying shelf liner and book covering material.
    Bertho
    Registered Tweakie's Avatar
    Nov 2009
    UK
    Hi Bertho,
    The best stuff I have found is the 'transfer tape' used by the sign making industry. Works for me.
    (I also cut sign vinyl (drag knife method) so already have the low tack transfer tape on hand - comes in anything up to 1M wide rolls).
    Tweakie.
    CNC is only limited by our imagination.
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    Agree with Tweakie, only one addition - keep you attention on fact that you need PAPER-BASED transfer tape. Usually this is cheapest one. Suppliers also can offer plastic-based which is not suitable for your purposes.
    Jun 2007
    Thanks for the fast replies.
    I will try the suggested paper transfer tape.
    Bertho
  1. My first success with home made protective bellows
    By guru_florida in forum Mechanical Calculations/Engineering Design
    Last Post: 05-13-2013, 07:21 PM
  2. EMI shielding
    By bigalow in forum General Electronics Discussion
    Last Post: 02-29-2008, 09:18 AM
  3. Nylon/Rubber/etc for homemade protective bellows
    By guru_florida in forum Glass, Plastic and Stone
    Last Post: 12-29-2007, 10:18 AM
  4. Replies: 8
    Last Post: 04-09-2007, 01:58 PM
  5. Connection of shielding
    By cncuser1 in forum General Electronics Discussion
    Last Post: 06-17-2006, 08:57 PM
