Why not simply try it?
Adjust your z-height until you get the best result, mark the distance for future use and thats all there is to it!
Zoefie......
Hello
I am just working on some thin paper cutting and wanted to be absolutely accurate with my focus. I have a piece of acrylic 62mm square which came with the machine. I have been measuring 62 mm from the top of the plate holding the lens holder. This has been fine for most of the work I have done but for thin paper I want the beam as small as possible.
If anyone has any advice or instruction on exactly where the 62mm should be measured from I would be grateful
carl
3040 laser (rabbit)
rabbit / ls3040
Zoefie......
are u saying u use a 2.5" to cut paper? try use 1" - 1.5" , u ll get tinner spot. made a mesuarement , from lens head cone till material surface, ( u can get it and cut a acrylic and use it as FL model )
