Results 1 to 6 of 6
Thread: will a 1w diode laser cut 6mm acrylic?
    Feb 2009
    canada
    Smile will a 1w diode laser cut 6mm acrylic?
    Need help, I'm thinking about adding a laser to my CNC but want to do it on the cheap cause the only thing i'm planning on cutting is 6mm acrylic. Anyone have any suggestions on this? Any help or ideas would be appreciated.
    Registered Litografa's Avatar
    Jul 2008
    Lithuania
    No. You need much powerful laser for 6 mm acryl. And better and cheaper if it will be CO2. Try chinese glass tube for this application.
    May 2010
    china
    If you need to cut 6mm acrylic,i suggest you to buy 60w to 80w laser tube.
    Chinese glass laser tube is ok.
    If you want,you can contact me.
    http://www.vivinar.diytrade.com
    We offer best quality and wonderful service.
    welcome to Zhiya.
    Apr 2010
    China
    Quote Originally Posted by antonzedd View Post
    Hello,
    If cutting 6mm acrylic,both CNC router and laser engraver will be ok to do it.
    If laser engraver,I recommend you a 60watt laser tube,and maybe you can tell me the dimension of your material.
    If interested,you can welcome to visit our homepage in made in china,we are manufacture and have all sizes of great laser engravers,will also give you good price.
    http://chinajcut.en.made-in-china.com/
    My MSN is chinajcutcnc@hotmail.com
    BR.
    Shanny
    Registered oneeye's Avatar
    Aug 2005
    brazil
    i have a 2.4W 808nm laser diode and it dont do absolutly noting in crystal acrylic, it can engrave dark color acrylic, all i could cut is 0,5mm paper, 1mm black acrylic( cutting shows no good finish cause it must cut at very slow speed) and vinyl. I hook the module with rubberband in my laser machine.... watch video:
    [nomedia="http://www.youtube.com/watch?v=ziip9Zvi7L4"]YouTube- RickLaser - 2.4W 808mn Laser Diode Cutting Test[/nomedia]
    Dec 2008
    1. Need Help!- Adding laser diode module to CNC table?
      By antonzedd in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 06-19-2010, 10:02 AM
    2. What size laser diode is needed to burn paint off metal?
      By Chris D in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 08-05-2009, 06:51 PM
    3. Laser Diode for Etching and Burning
      By mhmslm in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-14-2008, 08:52 PM
    4. laser diode
      By zoltan in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 12-21-2007, 01:40 AM
    5. What can I do with my Diode Pumped Laser
      By ronateah in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 08-31-2006, 11:28 AM
