When you turn on the laser does it initialize correctly?
The head should move to the back right and locate the limit / home switches and stop.
If so, can you manually move the head around the table using the software controls?
If you can, then your machine is likely ok and it is a programming issue (job setup using Newlydraw).
Zax.
LinkBack URL
About LinkBacks
