I really need help with this. Searched the forum and the web but couldn't find a solution.
Hello,
I'm new to laser CNC machines and need some help.
I've recently purchased a used Chinese laser engraving machine with a new laser tube. The machine uses the MPC6515 controller and it came with a USB key and a CD containing drivers and LaserCut 5.3. The firmware version on the controller is 3.0.3.
The machine is working 100%. I was able to cut and engrave some of the files left stored in the controller. And I installed the drivers, the USB key and LaserCut without problems. But I am having trouble connecting the machine to the computer via USB and cutting files exported to a USB stick via LaserCut and loaded into the machine. When starting the loaded file the machine would only give an endless beep, and the only thing I can do is turn the machine off and then back on. When I connect it to the computer via USB, the machine is not recognized, and when I try to export the cut in LaserCut directly to the machine I get a "Communication is broken for timeout..." error.
Any help would be appreciated!
Put here more detailed information about model, put pictures.
Did you tried different USB cables?
Thank you for your replay, Litografa.
The machine is MBL YH-G5030, but i think it's branded (no word about the machine on the MBL web site). I belive the manufacturer to be www.laserworld.com.cn. Yesterday I installed a firmware I downloaded from www.leetro.com. Now I can create a file in LaserCut, export it to a USB stick and output it on the machine. But still not able to connect the machine to the computer. I tried two different USB cables, and three computers all of them running Windows XP SP3. The current firmaware is 4.1.0.18. When I tried tp install any newer version, the machine would only display the "System starting..." screen. I also discovered another problem. Tried to engrave two different files, and the machine would sporadicly just stop after a few minutes of engraving. I also got burnt/melt corners when tried to cut something because the machine slows down too much at the corners. Any idea how to avoid this?
Sorry, looks like you have software/board problem. Best way is contact with manufacturer. Or wait when somebody will help you here
What I don't suggest to you for the future is downloading firmware from one site and installation into laser made by another manufacturer. It could help, but could also damage your laser mainboard.
Hi just read your post I have been doing some reading on this same controller as I have one on the way anyway not sure if you have seen this may be of some help.
Programming a MPC6515 controller
Thank you.
I installed the 4.1.0.13 firmware and now the engraving is OK. But still can't connect to the computer via USB.
I had to reload the print drivers to get the machine to connect through the USB cable - It has to be connected and then go through the "new hardware found" process- It took me a while to get it to find the appropriate file but once it had, everything was fine. Up until them, I have been using a USB stick to upload files
In my case it may be that the controller is faulty. I get no "Found new hardware..." message. Nothing at all.
If you are cutting and engraving using a memory stick , then I dont see how it could be the controller. I will have a look tonight and see where I had to put the drivers for it to be recognised.
If you go to the Device manager on you PC you should have a Stepservo device along with a MPC03 device off that. Right click the MPC03 device and update the driver - I think you have to have them on your desktop or somewhere you can easily access them - It worked that way for me.
If you dont have this step servo file then you need to get a copy of it - I am pretty sure it came off my original setup disc came with a driver file named "ezusb" in the english USB directory .
I am sorry but I did this some time ago and my memory of it is a bit hazy
I could be a windows problem.
Are you using XP or Vista? Many of these controllers are not working too well under Vista or Win7.
