you can use a piece of thin foil as a barrier in a co2 laser cutter. It wont go through any thickness of metal.
Even with an unfocussed beam the laser is strong enough to make a mark and ruin the other side of your box so a barrier of some sort is the best way to go.
I have never had any kind of splatter from the laser hitting metal but the metal could heat up and melt plastic if it is touching it.
LinkBack URL
About LinkBacks
