Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: WK40 to "Hybrid" laser B new main board
    Registered GuiBerlin's Avatar
    Jan 2010
    Germany
    Question WK40 to "Hybrid" laser B new main board
    Hi all
    OK, short story first
    Two month ago I got my co2 laser from wklaser in China.
    Surprise... when I opened the (huge) box, it was in parallel port and not in Usb...
    I contacted immediately wk laser and they recognized (immediately too) that it was their fault...
    The machine worked well though... but as some here know I could not do what I wanted to do : rubber stamps with slopes.
    So after a lot of emails we agreed they would send me another main board and I would change it myself (at least try...).
    Last day came the board
    It seems to be a chines Board but the chip and driver is from philips; lpc214
    It came with a new softdog for newlydraw.
    It came with a external panel too but I probably ask more question about it in the future
    So I installed the board, played a few hours with it and everything seems to work.
    I have a lot of new options in newlydraw.
    It is recognized as "Laser B" from wklaser.
    So here is my question :
    I control the laser with that external module :
    How can I control directly the laser from Newlydraw (since there are a lot of option about it) and not anymore from that external module?
    Is there anything to connect between the mainboard and the laser board?
    The external module is connected on the laser board on "j2".
    On the new main board there is a free port called "dac-out"
    I would really appreciate your help
    Dec 2008
    Newlydraw can control laser power (properties from engrave screen, near where it has the make/model of the laser), and it sounds like your driver can too (the analog output) but all that depends on the laser PSU.
    You will need to connect the DAC output to the 0-5V analog input on the laser PSU providing it has one, some of the newer PSU's only have a digital PWM input in which case you'd need an adapter board.
    I suggest getting some more information from the wklaser on how to connect it.
    Zax.
    Jan 2010
    Germany
    Hi Zax
    Thank you very much for your answer!
    You are right (of course you are!)
    After talking with WK they told me the PSU doesn't have a input... and that they will see how to deal with that (which means probably send me hone I hope :-) )
    The good thing is that 2 days ago I had no clue about "what is a DAC"... Never say die
    Jan 2010
    Germany
    hello !
    update...
    I got (free of charge, thank you Wklaser) a power supply with which I am suppose to control my laser beam from the computer and not from that power gauge anymore.
    They wired it for me but I think it is wrong for what I want to do.
    Here is an overview of the PWS :
    As you can see below they use the yellow green red a black (the orange one is not connected ) cable and connect the to a single connector :
    The plug end up to the "out" connector of my mainboard :
    So it "works". I can fire the laser.
    But... I do not have any control of the power.
    So if I get it well, I need to connect that (the DAC out) :
    on that ( 0-5V analog input ) ???
    Thank you very much ! :-)
    Dec 2008
    It appears to be the correct wiring for digital (PWM) control which is better than analog, so you should be able to control the laser from software.
    Are you sure it isn't controlling the laser power?
    Create 2 lines, and set each to a different 'power' layer (like 5% and 50%) and see if there is any difference on a piece of wood.
    Zax.
    Jan 2010
    Germany
    Hi
    I tried and tried again... even at 0% it fires the beam (at 100 % I think)
    Yep but I really not sure the pws supports PWM (which doesn't make any sense since they sent me and wired me the pws for that very purpose...)
    Have a look here (it seems to be exactly the same ) :
    40W CO2 Laser Power Supply (non PWM)
    But in the other hand, here is a link (thank you google translator) from the manufacturer of the pws which says :
    Laser power adjustment can either enter 0 to 5V analog signal, you can also enter the PWM signal to control the size of the laser power.
    jnmydy.com
    But I really try every single setup and really nothing change...
    So if I want to try with the analog way, I connect the dac out to the "G in/+5v" connector, what about L/+5v (black and red one) ? Does it need to be connected to the "out" connector on the mainboard still ?
    Thank you !
    Ps ; do you know what is d+ d- ?
    Dec 2008
    The Lightobjects PSU is the older non-PWM version but yours is definitely the newer one.
    D+/D- select digital inputs, active high and active low. I believe having the jumper on is active low but could be wrong. It has been a long day, I just arrived in Tokyo.
    Have you put a scope or meter on the Y/G connections to see if there is a signal?
    Since it appears you are only getting 100% with no modulation it is possible the driver needs to be updated for a PWM power supply? Did wk mention this?
    It would be easy to check the analog operation to confirm and no it wouldn't want to be connected to both PWM and DAC outputs - that could result in damage.
    Zax.
    Jan 2010
    Germany
    You're in Tokio ? I'd love to go there !
    Thank you again for you answer.
    I am going to buy some cable and try the DAC out one.
    In the meanwhile I asked wklaser about the driver update possibility.
    Wait and see
    enjoy your trip !
    Jan 2010
    Germany
    ok I bring back my old thread up...
    I come and "beg" for help :-)
    Electronic isn't really my world so I may ask questions which may seem really stupid... but I am willing to learn :-)
    Last time I posted about that subject was about 1 year ago... just before getting a new job. Which means I haven't try anything since then.
    OK... so basically I have that tiny cheap 40w laser machine from Weike.
    It came in parallel even though I ordered a USB version with PWM (to be able to engrave slopes on rubber stamps).
    They acknowledged their mistake and sent me a new main board and a power supply. (see the pictures bellow).
    I can move x and y without problem, and fire the laser.
    THE problem... I do not have any modulation (so no control at all on the laser except fireing it at I believe 100% of its power)
    Yes I did and I get 3,2V and it stays stable
    I asked Weike about it but gave up last year when I got my new job... I sent them an email yesterday but with the new year celebration so far nothing.
    Ok so I would like to try the DAC out possibility.
    Could someone help me with the wire ?
    from the mainboard do I have to connect only the dac out to the PS or is there anything else to do ?
    thank you very much
    Dec 2008
    Unless I am missing something, it looks like you are wired correctly?
    Zax.
    Jan 2010
    Germany
    Quote Originally Posted by zax15uk View Post
    Zax.
    I think so too... but still... no modulation.
    Can you tell me more about it? You are talking about the Dac right ?
    Dec 2008
    Yes - you should be able to use your volt meter to see if the DAC output is working.
    Zax.
  • Page 1 of 3 123 LastLast
    1. Sieg X3 "hybrid"
      By freesbank in forum Machinist Feedback
      Last Post: 03-05-2010, 11:20 AM
    2. Need Help!- Fanuc 18i-T "1114 main spindle orient fault"
      By Jeff_Mezzo in forum Fanuc
      Last Post: 01-28-2009, 09:30 PM
    3. Problem- Laser fires on "Laser Test", but not from software
      By SimonArthur in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 06-18-2008, 03:32 PM
    4. Add "View New Posts" to "Main Menu"
      By Mr.Chips in forum Forum Questions or Problems
      Last Post: 04-21-2004, 11:54 PM
    5. "Services For-Hire/Wanted" message board
      By samualt in forum Forum Questions or Problems
      Last Post: 03-16-2004, 09:29 PM
