Go Back   CNCzone.com-The Largest Machinist Community on the net! > Engraving and Art Design Software > General Jewelry Design Software
General Jewelry Design Software Discuss Jewelry design software here!
Old 11-20-2008, 11:35 PM
sa6200 is on a distinguished road
Help with Feed and Speed
Hello gangs,
Whenever I needed help or needing advises, you all have always been there for me. For that, I really appreciated. Now with that sucking-up out of the way, I need some help with my engravings.
I have been milling for years and haven’t had any problems to speak of except for the recent engravings. Enclosed please find my pics of my recent engravings. I just can’t duplicate the same type of clean-cut engravings as the sample pics.
Here are my parameters if this would be any help: I am using Tormach PCNC machine, so the maximum speed is 4500 rpm.
Engraving cutter: Mostly using 1/8” conical or I do have a 3/16” spring-load 60 degree conical
I have tried both higher speed of 4500 and as low as 450rpm and getting the same results.
No coolant. Dry mill
Letter sizes: less than 1/8”
Please note the materials in the example pics are stainless steel.
Any suggestion on a proper feed and speed for brass and silver? or proper method that I should be doing.
Advice will be greatly appreciated.
ID:	70127   Click image for larger version
Old 11-20-2008, 11:48 PM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Dry with such a small cutter and at low r.p.m?
I would be using a two flute and flood coolant unless you can run a very high speed "40,000 - 60,000 rpm" and then the D.O.C. would still be less than .003 max per pass.
Jeff...
Speed & Feed kal_pesh Mastercam 4 02-23-2008 01:19 PM
Speed & Feed kal_pesh General CAM Discussion 1 02-20-2008 10:15 PM
feed and speed / sfm citra General Metalwork Discussion 3 03-17-2006 10:55 AM
Feed & Speed Help kaleem1 General Metalwork Discussion 2 11-04-2004 07:21 AM
speed and feed KBW General CAM Discussion 2 02-20-2004 09:18 PM
