Results 1 to 6 of 6
Thread: hardware and software
    Jan 2012
    Hello- and thanks for taking time to read this. i am a cnc machinist with 28 years experience in tool and die, and am looking for my first cnc router/mill engraver for some small businees ideas i have in mind. if this question has been asked before, please direct me to the appropriate thread.
    what i am looking for would be an entry level machine, with an approximate work envelope of 24"x36" with Z axis of 10". its primary function would be in wood, and non-metals, with the capacaity to contour mill, and do light engraving in metals.
    software to go with the machine to perform per above outline, using scans of artwork to vector and g code generation, and straight g code programming for basic functions.
    again, thanks for any help!
    Jan 2008
    It might be worth your time to check-out the Zenbot line of products. They are fast, inexpensive and accurate. The largest table length is a little shorter than what you are looking for, but it might just work depending on your requirements. I personally have the smallest unit offered by Zenbot (Mini) and have been active in using it for several years with little to no maintenance. I don't think you are going to find very many options with a 10" Z travel. Perhaps slicing the model in your CAM software into multiple layers with the eye to recombine would work.
    Zenbot CNC Routers
    Apr 2004
    Oakland CA USA
    Somehow I doubt a real tool and die guy
    will be very impressed with the accuracy of a ZenBot. They are inexpensive, and they do work to some degree, but for people who think in "tenths", even the best commercial routers will have a hard time measuring up...
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Jan 2008
    I have been pleased with the results being within 0.002" of models I have created in my CAD system. Certainly much more expensive machines can hold a higher tolerance I'm sure, but at what cost? Ultimately, it comes down to what your budget it and getting the best value for the money. I too would be disappointed if I couldn't hold a tolerance exceeding tenths of a inch, but that is certainly not the case with the Zenbot Mini I have.
    Jan 2012
    xcayba, thanks for your time taken to respond, i will check out the zenbot line. for the projects i have in mind, i would like to see if there if there is a market, and educate myself on working with different woods, feeds/speeds, cutters etc, while learning the software, so an entry level machine makes sense.
    awerby, .0002" in steel is practical, though temperature comes in to play, i would be primarily working in wood, so .002" is fine. the only metal work i have in mind would be engraving. and yes, i am in fact a tool and die cnc machinist and have been since 1983, working with okuma, fanuc, and mitsubishi controls, primarily on lathes, though i was originally schooled on mills.
    Apr 2007
    America
    for g-code, use Cam Bam
    short learning curve as good videos
    one user has provided the help file in form of PDF; print this out in color and you'll have a great manual
    also, lots of very good instruction [answers to questions] concerning 3D usage of Cam Bam in forum
    forum has lots of really smart, focused and very helpful people
    1. Hardware/Software recomendation
      By Autonow in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 04-18-2011, 08:42 PM
    2. Need Help!- Looking for help with software/hardware integration
      By GeoA in forum Controller & Computer Solutions
      Last Post: 01-23-2011, 09:59 PM
    3. What is the best hardware and software
      By JeffDavis in forum DIY CNC Router Table Machines
      Last Post: 09-14-2009, 01:20 PM
    4. Need Help!- Connecting hardware and software
      By tizdall in forum General Electronics Discussion
      Last Post: 07-03-2009, 05:22 PM
    5. Alien hardware and software
      By Ecclesiastes in forum General CAM Discussion
      Last Post: 01-06-2008, 09:03 PM
