Some of those pictures were pretty old. Here's a model of the machine that i made in sketchup. As you can see i also drew up a possible 4th axis arrangement.
As you can see the table is short, and causes the lathe chuck to take up some of the cutting area; but dont worry, when i was cutting out the parts, i made preporations to have an attachable lathe, so i cut out tables that were longer: 8" x 6" instead of the usual 6" x 6" table.
This will give me the area i need to be able to mount the lathe without compromising the amount of machine able area.
Also note that the size of the spindle isn't correct, the dremel i have will be longer.
LinkBack URL
About LinkBacks
