Results 1 to 4 of 4
Thread: HEIDENHAIN iTNC530
    Jan 2012
    iran
    HEIDENHAIN iTNC530
    Dear every one
    I have machining center with HEIDENHAIN iTNC530 control ,when i turn on machine ,i have {exchange buffer battery} .
    I want to know if i exchange it ,parameters and program of machine will be clear ? or no ?
    best regard
    ali
    Jan 2011
    UK
    you need to exchange it as soon as possible as this is back up power for memory when machine is powered off
    mick
    Nov 2008
    Finland
    Well, all the information except the date and the clock is on the harddisk.
    So you won't loose parameters nor programs.
    Anyway, I too advice you to change the battery. It is Renata CR2450N.
    Make sure you will get the right battery. (not just normal 2450)
    Jukka
    Apr 2012
    Make sure you have the machine powered up when you change the batteries. I bought a used machine and by the time I got a big enough phase converter(5-6 mos) it lost all machine parameters and programs and previous owner didn't make a back up copy of parameters. Someone should make battery tender like for motorcycles to keep plugged into 110 to keep batterys charged. Mine with heidenhain uses 3 AA batteries.
    Good luck, JD
  1. Need Help!- need postprocessor for hypermill to heidenhain itnc530
    By stripper in forum Post Processor Files
    Last Post: 07-17-2011, 05:18 AM
  2. Problem- Heidenhain iTNC530
    By Jay Roy in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 03-07-2011, 12:31 PM
  3. Need Help!- I need your help post Heidenhain iTNC530 for ProEngineer
    By nbthuan68 in forum PTC Pro/Manufacture
    Last Post: 10-23-2009, 01:16 PM
  4. Heidenhain iTNC530 First StartUp
    By Leha_Blin in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 11-29-2008, 12:30 PM
  5. Need Help!- Heidenhain iTNC530, how to change plane?
    By Martynas2 in forum G-Code Programing
    Last Post: 11-23-2008, 10:58 AM
