I have just started a machine shop, i recently moved all of my gear to a new location and scince then i have had 6 electronic breakdowns i only have 3 machines, the unit is a little damp but i have a dehumidifier, does any body have any suggestions as to why machines are breaking, its going to end up costing me my business.... |
| What are the nature of the breakdowns? I agree you need to check for correct service voltage. Al.
| no tests have been carried out, i wouldnt know where to start with that? the breakdowns have been 2 screens ,graphics card, fapt card, inverter for tool changing carousel, and a couple of minor circuit boards which i managed to repair myself. is it likely to be the damp? Thank you for your replies im most grateful for any help i can get. |
| Unless the humidity is extreme, I would not suspect that, inside cabinets are usually warm, the boards would have to be cold and come in contact with humid air for condensation problems, the low logic level boards are usually cushioned from service power voltage variations due to switching power supplies keeping the DC levels constant. The inverter might be an exception. If FAPT is used, these are Fanuc I presume? Fanuc recommend a service supply with +-10% of the operating voltage, this is often 200vac as this is the standard supply in Japan I believe. It may not hurt getting the supply voltage checked, just to eliminate it from the equation. Or you might be just having a streak of bad luck ![]() Al.
| CR Electronic | blahic11 | Europe Club House | 2 | 11-19-2011 05:31 PM |
| CNC electronic components. | bkboggy | DIY-CNC Router Table Machines | 40 | 02-01-2009 08:34 AM |
| '06 Electronic setup? | bkboggy | Joes CNC Model 2006 | 5 | 01-26-2009 11:04 AM |
| New Machine Build- Electronic are just about complete! | solodotcom | DIY-CNC Router Table Machines | 1 | 07-14-2008 08:58 AM |
| Schonbuch Electronic | HillBilly | General Electronics Discussion | 6 | 08-02-2005 12:49 PM |
