Old 02-22-2010, 12:10 AM
Captain Midnigh is on a distinguished road
Need help wiring spindle drive
I have a Milltronics Pardner 4 that I fitted an Ajax Mach3 controller to. I need a pinout for the original inverter, so I can wire it to the controller. I can't tell what brand it is, but the model is: CIMR-5.5 G2 E10. I can find no referances to it anywhere. There is no information in my Milltronics manual.
Thank you for any help
Old 02-23-2010, 12:21 AM
cncsnw is on a distinguished road
CIMR-xxx sounds like Yaskawa. Yaskawa drives are often found under other nameplates. 5.5 would probably indicate 5.5kW power capacity (i.e. 7.5HP). "G2" would probably be the model/series.
Does yours have discrete, labeled screw terminals, or just plugs (e.g. Honda connectors)?
Does this look like your unit:
http://www.yaskawa.com/site/dmdrive....ile/TM4240.pdf
Old 02-23-2010, 02:05 AM
Yes, thank you for your help.
1992 VF2 Alarm 123 spindle Spindle Drive Fault dafowfidy Haas Mills 15 05-14-2012 01:32 PM
GE Fanuc drive wiring info Bob Pierre General CNC (Mill and Lathe) Control Software (NC) 4 01-09-2010 09:38 AM
Need Help!- Wiring 8 wire hobbycnc with Gecko-like drive Guldberg Stepper Motors and Drives 2 07-20-2009 08:52 PM
Need wiring diagrams for GE Spindle DC drive Banzai11 General Metal Working Machines 0 09-10-2008 10:46 AM
Cincinnati Arrow 500 Spindle Drive wiring professor CNC Machining Centers 0 11-23-2007 07:47 PM
