Old 02-20-2010, 09:13 AM
mattbesquare is on a distinguished road
Any benefits running 220 instead of 110 to my power supply?
I have an unregulated 72v 12A powersupply running my servos. Any benefits to 220 instead of 110? Is 220 cheaper, or more efficient?
Thanks!
Old 02-20-2010, 09:17 AM
Al_The_Man's Avatar
Providing supply conductors are sized correctly, you would not see any difference.
Generally the higher voltage allows smaller conductors resulting in cheaper installation cost.
In your case the primary current is small anyway at either voltage.
Old 02-20-2010, 09:23 AM
MyCattMaxx's Avatar
MyCattMaxx is on a distinguished road
I agree with Al.
Your power supply at full output uses 864 watts.
At 120 volts that is only 7.2 amps. At 240 halve the current draw from the mains.
But no matter which way you go your power meter will still show 864.
Old 02-20-2010, 08:08 PM
Thumbs up
makes sense, thank you! :-)
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
What are the benefits for non-center cut endmills nagjames General Metalwork Discussion 4 06-20-2007 12:42 PM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
benefits of incremental? paelscrit G-Code Programing 15 01-27-2006 09:27 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
