Old 04-18-2005, 07:53 PM
mannster is on a distinguished road
Question Cool little chip !!!
Check this chip out ! It has a built in chopper circuit and drives bipolar drives.
The bad news is 1 Amp maximum. ST L6219 Chip
Oh well, maybe somebody here can benefit from this. They are about $3 at Digikey. It seems like a low powered version of the 297/298 drivers we have here all in one chip at a super low cost.
Can the voltage be amplified somehow ???
Old 04-18-2005, 09:51 PM
drawbar's Avatar
drawbar is on a distinguished road
Take a look at the ST L6208. It also has current chopping, bipolar, will handle 2.8 Amps, and up to 55 Volt supply. But, it is a bit more expensive at $9.80 from Mouser.
http://www.st.com/stonline/books/pdf/docs/7514.pdf
Brian
Old 04-18-2005, 10:08 PM
Wow ! that IS awesome ! I may want to give that one a try later. The current handling capabilities are fine with me.
I found driver schematic for this : L6208 based board
But I will research this solution a little more before I try it.
Old 04-18-2005, 10:19 PM
2muchstuff is on a distinguished road
Why can't someone make one to handle 6 amps. I would be tempted to make up my own driver board verus buying a premade module.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 04-18-2005, 10:31 PM
You mean a chopper that peaks at 6 amps !? WOW !
I think the most important thing is beefing up the traces on a circuit board to handle that kind of current. The L298 handles a MAX 4 Amps and I believe you can "double" them up to increase the current handling capability.
Is this correct ???? If so, then this should make 6-7 amp handling possible.
QUOTE: ...For higher currents, outputs can be paralleled (see datasheet)
This could get interesting....
Old 04-18-2005, 10:40 PM
I was never a big fan of doubling (piggybacking) things up. I still like using things that are in one package. It just seems that when there is some kind of oscillator or the like in both chips then one will be bucking the other due to tollerance differences between the two.
Old 04-18-2005, 11:36 PM
Gotcha.... Maybe you could just replace the 298 with your own discrete H-bridge circuit.
Hmmmm... this is a problem I will be facing in the future.
Old 04-19-2005, 12:44 AM
Now that defeats the purpose of having everything in one nice neat tidy package. Now we are back to square one.
Old 04-19-2005, 12:55 AM
gregmary is on a distinguished road
If you are looking for that kind of current I think you will need to go with a discrete H-bridge. It all comes down to power disipation in the FETs and the only way to get more current through the chip is to be able to disipate the power that gets wasted in the junction. And the way to do that is use a larger die, thus you are limited to the number of transistors in one chip. Discrete fets are pretty cheap, about a buck apiece. What is wrong with using a controller chip and descrete H-bridge?
Old 04-19-2005, 07:56 PM
H500 is on a distinguished road
There's a thread on a DIY spindle motor that is based on simple discrete h-bridge mosfet circuit and a driver chip. In THEORY, this will handle 10-20 amps at any voltage.
Don't forget that microstepping is essential with high performance motors. Otherwise, resonance is likely to make the system unusable.
  #11   Ban this user!
Old 07-22-2005, 04:06 AM
Mat-C is on a distinguished road
Just to repeat: please don't double these things up
They need to be able to cut current/recirculate/etc.... and even if by some miracle that worked, what if they were on difference output phases?
Does anyone make a chip conveyor that works? bob1371 Machine Problems, Solutions , Wireless DNC, serial port 5 12-12-2010 03:39 AM
pic chip SERIAL to step/dir and controll berin Open Source Controller Boards 13 02-18-2005 05:23 PM
drilling peck chip break fjd G-Code Programing 20 12-12-2004 06:10 PM
Cool cheap 3D modeler ger21 General CAM Discussion 0 04-05-2004 10:04 PM
Proper Computer and Chip for Mach 1 HomeCNC Mach Software (ArtSoft software) 12 03-17-2004 09:14 PM
