Old 02-15-2010, 08:30 PM
KT6G Radio is on a distinguished road
Trying to understand what I need?
Hi All,
I have three g203v gecko drives and three stepper motors from Kelling Tech (KL34H260-42-8A). I also have the CNC4PC breakout board C11 Multi-function board. I am thinking of using two motors to drive the x-axis (2 roton ball screws drive the x-axis) and was wondering if the BOB would work for this.
I know I need another gecko drive and motor, but was wondering how I can drive the two x-axis motors in sync or if this is problem. I also have the KL-7212 (Unregulated Power Supply 864W, 72VDC/12A, Single Rectifier Module,120VAC or 230VAC) and was hoping that this is enough power to drive four motors.
Also should I power the BOB and other low voltage electronics with a separate power supply (5v-12v)?
The router is an all metal/aluminum and I will use a Chinese Spindle. I want to be able to cut soft metals (aluminum, brass, copper, etc.) and wood of course.
What other electronics, besides a PC will I need? E-Stop, home and limit switches, etc. If someone has a list of the needed electronics, plus nice or neat stuff to add to the system for smoother or better operation, I am highly interested in any help. Also I have Mach 3, but what other software do I need? I don’t understand the difference or what I need to consider.
Of course my budget is limited, so I need to make some smart informed choices, thanks for your help.
Paul
Old 02-18-2010, 09:07 PM
ger21's Avatar
You slave the two together in Mach3. Set up the 4th axis as the A axis (with same settings as X), and slave it to the X. Config>Slaving
You don't need anything else, but you might want them. It's really up to you. I don't have any switches on my router.
Mach3 controls the machine. You'll probably also need a CAD or design program, and a CAM program. Mach3 comes with LazyCAM, but I'm not a fan of it.
Help me understand chezrad General CNC (Mill and Lathe) Control Software (NC) 2 06-21-2007 08:26 PM
Need someone to help me understand this stuff. tersmurf Mentors & Apprentice Locator 3 01-05-2007 09:19 PM
I don't Understand automizer Phase Converters and VFD 14 01-01-2006 11:43 PM
Cad/Cam Example - Help Me Understand bill south General CAM Discussion 1 06-29-2005 02:47 PM
I just dont understand... freezer General CAM Discussion 19 02-11-2004 11:55 AM
