Old 02-05-2010, 02:20 AM
Akros is on a distinguished road
Sensors selection
I need to measure the displacement of an arm,I need to know the exact position all the time.With a really big precission.
I've been thinking in:
-Rotatory encoder, which I could count revolutions and get the position.
-Magnectic sensor, in this case, im not sure because i need a range between 0 and 30 cm.
-Optical sensor,the same as magnetic sensor.
In this case, which would be the cheapest option? the more reliable?
Thanks!!
Old 02-05-2010, 06:58 PM
H500 is on a distinguished road
What mechanism are you using? What resolution is "big precision"? 1cm? 1mm, 1um?
Optical encoders are pretty cheap and reliable. CUI has a 1000 ppr one for less than $50.
Old 02-08-2010, 06:52 AM
The precission is about 0.1 mm.
The mechanism is unknown for the moment, but it would be a DCmotor with a spindle or a Stepper motor.
Old 02-08-2010, 04:51 PM
Al_The_Man's Avatar
.1mm would be easily achieved with a differential encoder, the error usually comes in the mechanical linkage, i.e. if the encoder is on the motor, then the only error is mainly if backlash is present.
Need Help!- Using inductive sensors with Mach3 & C11 George General Electronics Discussion 14 05-05-2009 05:49 PM
proximity sensors for homing or thc? Wolfesmetalfab General Electronics Discussion 0 12-03-2008 12:30 AM
Need Help!- Vane Position Sensors frankg521 General Electronics Discussion 14 07-31-2008 07:06 AM
Inductive Proximity Sensors nickfox General Electronics Discussion 3 09-06-2006 09:15 PM
proximity sensors wired General Electronics Discussion 7 09-30-2005 11:29 AM
