So I'm still pretty green to circuits and the like so when I did the calculations and came to my answer it seamed way to easy... Ohms Law: I=V/R or in my case R=V/I So my power supply pumps out 45v @ 3A and I want 12v so I don't fry my little heat sink fans. That being said the voltage difference is 33v Thus, R=33/3 and R=11 Ohm So I need 11 Ohms of resistance to get 45v@3A down to 12v@3A; right? Mmmmm, circuits ![]() |
except the current you should use is that actually drawn by the fan not what your powersupply is capable of supplying. A typical fan might only take 0.1A so the calculation should be (45 - 12)/0.1 = 330ohm (per fan). You need to find out what your fan actually requires - read the spec sheet or easiest way is a multimeter and a 12v car battery.. The other thing you need to take into account.. the resistor will get hot... how hot? well, using my example W = VI = 33 * 0.1 = 3.3W so at least a 5W rated resistor will be needed (one per fan) Lets say you had 3 fans, one on each axis, each taking 0.1A; do you use one resistor per fan or one overall? Well if you use one resistor and one fan bearing starts to go, then that fan takes more current, pulling the voltage down and slowing the other fans down. So as a general rule it would be better to use seperate resistors. Another reason is that the resistor would dissipate three times the heat i.e. 9.9W so a 20W resistor is needed which wil be more expensive and bulkier than three 5W ones. Personally, I'd use a seperate 12v supply for the fans as the whole point of the fans is to remove heat, not generate more!
__________________ If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com |
The fans are 12v .09A so I was rounding to .1A as well. But then I thought well why? Why cut the Amps down? the 3 fans will only draw what they need (.3'ish Amps) so whats the point of cutting the Amps down? 3 Amps wont hurt the fans its the Voltage that frys them... Right ![]() I was leaning toward using one resistor and running all fans from this 12v source. I only have 3 fans now but have plans to add at least 2 more for the enclosure I'll be making. I know the resistor will add a bit more heat but if needed I can just add a fan to that too I don't care. What I want to avoid is a wall wart power supply... Its easy sure but I want to know for sure that when the power supply is on the fans are running and if its off the fans are off. And tapping into the 45v supply makes the most sense if you're going that route. EDIT I've even thought about using a 12v fixed voltage regulator but the max input is 35v. So really in order to make that work all I need is a resistor to drop the volts to 30'ish then run it to the regulator. But would that be better than one resistor? I was thinking what if my power supply fluctuated for some reason; the regulator would well, regulate... Last edited by MA$TER_E; 02-03-2010 at 01:09 PM. Reason: Added a voltage regulator thought |
| Why not use the PC 12v from one of the 4 pin connectors? Al.
| Well its the Watts that fries things W=V*I Raise the voltage and you raise the current so power increases exponentially... Things get hot fast. Try this, run your fans in series .... 4 fans = 48 volts... but if one dies they all die. |
| Isn't the PC power supply already available? Al.
| No, the only lead coming from the PC is the parallel cable that connects to my break-out board and thats it. Other than that its isolated from the PC. I could run a lead from inside the PC to the parallel cable then over to the control box but thats what I want to avoid. I've got so much power right there. Its only inches from where its needed I just have to adjust it some in order to use it. |
| If you had a linear power supply, it is often easy to add an overwind in the transformer, about 16~18 turns. Switching supply, not really posible. Al.
#11
| It dead simple on a toroid to add an overwind, generally around 2turns/volt, you need around 8.5 vac, add a small bridge rect. and cap and you have ~12vdc. The voltage is not all that critical for fans. Use some small gauge single strand enamel'd copper preferably, around 20g would be plenty. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 02-03-2010 at 06:43 PM. Reason: turns/volt corrected |
#12
(edit)Al's suggestion of an overwind is a good one, if you can get the toroid apart. It would probably be slightly cheaper but obviously more work... (/edit) (edit2)Its 45 off load, 40 on load.(/edit2)
| Check this out !! | weirdharold | UG NX | 1 | 07-05-2009 06:13 PM |
| Can someone check this out!!!!! | macgemby | JGRO Router Table Design | 5 | 10-09-2008 12:10 AM |
| Spell check it out!!! I just noticed CNCzone now has spell check! | HayTay | CNCzone Club House | 3 | 01-19-2007 07:59 AM |
| Check this DRO | Konstantin | General Electronics Discussion | 0 | 05-02-2004 11:41 AM |
| Ohms/coil, need amps? | thuffner3 | General Electronics Discussion | 2 | 01-04-2004 02:13 PM |
