Hi, I was just wondering if anyone has any good power supply sources other than ebay and www.mpja.com. I have to purchase something over $100 US before they will ship to Canada and the power supply that would be good is less than half of that. I don't really want to buy a whole bunch of extra stuff just to make 100 buck total. I'm looking for a 24 to 32 Volt power supply and 7 amps or up, but lower may do aswell. Thanks. |
| If its an option you can make a power supply from an old microwave transformer. Bubba has a great how to in the forums. I tried to find a decent transformer here in canada as well. Its not as easy since we don't really have any companies like surpluscenter up here. The real problem is the weight of the transformer, cuases the shipping to usually be more then you pay for the transformer. Have you tried princess auto, sometimes they get a decent transformer in or they have some that can be rewired fairly easily. I built my transformer and powersupply, in the end only cost me about 30 dollars. I had some help from some great people here on the zone and FrankG from theworkshop.ca.
__________________ Have a good one. Dave |
| What kind of voltage output and amperage comes out of these transformers, I heard that taking apart a microwave is dangerous because of the radiation. Just so happens that our last microwave just broke down, not a power supply malfunction either. Could you give me more info on this. I'll look at Bubba's forum. Thanks. |
| Microwave ovens DO NOT HAVE ANYTHING RADIOACTIVE IN THEM. The only time they produce radiation is when the magnatron tube is energized. The magnatron tube is nothing more than a fancy vacuum tube, like the ones use in the old tube t.v.'s. The voltage that comes out of these transformers on the secondary side can be in the 1000's of volts. What you will end up doing is stripping the secondary side off and replacing it with a new lower voltage one. Something that you can deal with.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| Here's Bubba's how to, its not hard to get the wire off the transformer and even easier to put the new wire on, once thats done test the voltage and your done. http://www.cnczone.com/modules.php?n...warticle&id=27
| I will probably put my order in for mpja.com, I'm not too sure about discharging the caps with that much voltage they can kill. I would have to know the proper way to do it, and still it could be dangerous. Thanks for the help guys. Really appreciate it. |
#10
| Joe2000chee, I never got around to doing any pictures of the procedure as the whole thing takes about two hours to do. Next time I make one, will try to remember to take the pictures.
__________________ Art AKA Country Bubba (Older Than Dirt) |
#12
| The only thing to watch for is the cap charge http://www.gallawa.com/microtech/cap_test.html and even then if the microwave has been off for some time the cap usually has bled away. Al
| How does a power supply work. | ynneb | DIY-CNC Router Table Machines | 1 | 07-27-2011 09:40 AM |
| Diy Power Supply Choices | berin | DIY-CNC Router Table Machines | 11 | 07-13-2005 03:47 PM |
| 5 Volt Power Supply Tripping | murphy625 | General Electronics Discussion | 13 | 02-27-2005 09:05 PM |
| Is this power supply rating adequate? | jerryrigge | General Electronics Discussion | 3 | 11-25-2004 10:06 AM |
| Choosing a Power Supply for Retrofit? | pfeist | General Metal Working Machines | 4 | 05-23-2004 10:36 PM |
