Old 01-31-2010, 11:05 PM
warhorse is on a distinguished road
New Machine, Need Help, Suggestions?
HI,
Im new to the forum, glad to be here. I just received my new machine, which had practically no support documentation with it, so Im really winging it, with only some CNC experience on a Techno machine.
The machine has 4X8 bed, has dual spindles, and dual 4th axis rotaries. Its one of the 1325 models commonly seen, with 90 VDC spindles (3.5 KW). It seems like a decent machine. Ive attached photos of the machine and its components to help in the discussion.
so Heres the problem im having...
I tabbed to the Jog window, pushed Y+ button....machine moved Y+. Pushed Y- button and machine moves yet again Y+.
I tried to jog Z and X axes....No response. Only jogging is in Y+ direction using both Y+ and - Buttons or analogous shift arrows.
I have the X,Y,Z axes steppers plugged into my console, but the spindles and the rotaries are not plugged in yet.
Ive installed mach3 ver 2.63. Im carefully and slowly working through the mach manual. Checked the parallel port driver....looks good on my system, as far as I can tell. Switched on the control console, CNC steppers initialized with brief vibration.
I PMed a user on another board and he suggested: "It could well be wrong pin assignment but could also be loose wires or even your drive is configured for CW/CWW instead of Step/Dir."
"your drive is configured for CW/CWW instead of Step/Dir." Im uncertain how to check this.
Other things I thought to check are:
- Parallel port cable could be bad - I checked all pins, cable is good
- wiring may be wrong - find and check a schematic for misplaced wires
- check wiring on stepper sockets plugging into console.
- Trace jog voltage from breakout board to motor, find any continuity breaks
- Run mach3 on another computer to check for same results
Im sure this problem has been discussed, any advice or direction would be great!
thanks in advance,
Warhorse in SC
jon.johanssen@gmail.com
Need suggestions for CNC machine or laser cutter peterpan5 Want To Buy...Need help! 0 12-06-2009 09:18 PM
Need Suggestions on Machine Purchase Please coleasterling DIY-CNC Router Table Machines 0 06-09-2007 11:02 PM
New machine suggestions Greg Mueller Fadal 7 10-25-2006 11:31 AM
Need suggestions for controller for MaXNC15 oL MACHINE Fixittt General CNC (Mill and Lathe) Control Software (NC) 0 07-14-2006 05:55 PM
Suggestions for machine? matth DIY-CNC Router Table Machines 6 09-15-2005 02:50 PM
