I have an application where I need to output a 0-10V analog signal at least 14 bit would be nice, may settle for less. I would like to use a PLC to output a certain voltage when a certain input is active. For example, I would like to have 8 switches connected to the PLC. When I push button 1, the PLC outputs 1V, button 2 outputs 3.7V, etc. The voltage values are arbitrary and I would like to be able to set them using buttons and a small lcd screen on the PLC. That way I could change the voltage output for each button, use them for awhile, then change them to something else when I needed to. I have used zelio smart relays in the past and they have everything I need except an analog output. Something similar is what I am looking for. Something like this but with analog output: http://www.us.telemecanique.com/prod...lay/index.html Any suggestions? Thanks Matt |
| Have a look here> http://www.divelbiss.com/ I have bought a bunch of these for the plant I work at. They are fairly inexpensive, easy to program, and they have pretty good software for creating your ladder. Quite compact for a simple application like yours. |
| Not sure about your budget, but have a look at National Instruments http://www.ni.com/ for Labview and their hardware. Very flexible stuff and easy to use/modify as it is "virtual instrumentation" Steve |
| also check out these: http://flash.ezautomation.net/ http://flash.ezautomation.net/eztext...c_overview.htm I recently used the EZtextPLC on a project. Nice configurable IO with little plug in block. Looks like they offer 12 bit Analog. The one i ordered even had modbus/tcp I've also used a few PLC's from automation direct, and they also offer nice HMI interfaces (C-More) http://www.automationdirect.com |
| Another vote for Automation direct. I haven't used them in years (back when they were PLC Direct), but great value for the money. http://www.automationdirect.com/adc/...PLC)/PLC_Units |
| These are also very cheap. http://www.cubloc.com/product/03_01.php |
| And this is even more cheaper: http://www.audon.co.uk/cusb22r.html |
| Please suggest an encoder | justCNCit | General Electronics Discussion | 0 | 05-04-2009 07:37 PM |
| Can you suggest a method? | kaseencook | Vacuum forming, Thermoforming Etc | 4 | 04-19-2009 10:57 PM |
| Can someone suggest a CAD/CAM? | jimluu | General CAM Discussion | 4 | 04-28-2008 02:00 PM |
| Suggest a VFD | bcromwell | Phase Converters and VFD | 1 | 04-20-2007 10:11 PM |
| Can any suggest | CNCadmin | CNC Wire Foam Cutter Machines | 4 | 04-06-2004 10:23 PM |
