Old 01-17-2010, 10:13 AM
cyclestart is on a distinguished road
DRO on the cheap ?
I'm buying a large mill and it will be manual for the foreseeable future. DRO's with scales large enough to cover the full travel are beyond my budget. Otoh, counting screw rotations is a pita.
Would it be practical to hook these encoders to the screws ?
http://preview.tinyurl.com/yds9qt4
And then use a pc as the counter ?.
I think I can handle the software end of things. The wiring bit is not in my comfort zone.
It should be at least as accurate as reading the graduations on the collars ? (hoping)
Anyone who says "It only goes together one way" has no imagination.
Old 01-17-2010, 10:45 AM
Al_The_Man's Avatar
Will this s/w work for you?
http://www.lindsayengraving.com/othe...rests/dro.html
Updated s/w here http://bellsouthpwp.net/A/r/Arts_home_page/DRO/
I have hooked the encoders directly to the port without the buffer transistors and worked OK.
Old 01-17-2010, 10:58 AM
WayneHill's Avatar
WayneHill is on a distinguished road
http://www.cadcamcadcam.com/usb-dro-sys.aspx
Wayne Hill
www.codemangler.com
Old 01-17-2010, 08:30 PM
Thanks for the replies.
The first option has a price that can't be beat.
The second option has some bells and whistles and likely some level of support from the manufacturer. The extras aren't something I will be needing anytime soon but good support has value. I'll give the free one a try before spending.
Neither of the options recommends a specific model of encoder. The one I linked to okay ? I'm picturing spinning the shaft with a belt..
Old 01-17-2010, 09:06 PM
Al_The_Man's Avatar
I found the differential line driver type I could input without buffers.
Old 01-17-2010, 09:53 PM
uh, can you offer a translation ? I'm don't have much electronic (or even electrical) knowledge. This project is going to mean learning some new things.
Old 01-17-2010, 10:34 PM
Al_The_Man's Avatar
The differential encoder has two each of the channels as output, you will see them labelled as A /A B /B etc you would just use the A & B of each output.
By buffers I meant you can do away with the intermediate transistors that are shown in the link diagram.
Old 01-17-2010, 10:52 PM
MyCattMaxx's Avatar
MyCattMaxx is on a distinguished road
The one from Lindsay will use this http://www.usdigital.com/products/en...otary/kit/e8p/
Old 01-17-2010, 11:25 PM
tusavision is on a distinguished road
Another option is to make a small bracket to affix a harbour freight pair of 12" digital calipers to your table, and screw the other end to a small push button mag base like off of littlemachineshop.
Old 01-17-2010, 11:36 PM
MyCattMaxx's Avatar
12'' isn't a large mill. He stated a large mill.
  #11   Ban this user!
Old 01-17-2010, 11:56 PM
Beats the old system of a counting revelutions or a dial indicator & 321 blocks.
The mag base means it's adequate for parts smaller than 12" which for many users is good enough.
Didn't say it was ideal. Compared to a cheap encoder system: it may not even be economically competitive. Particularly if there's a potential for scrapped parts.
All the same: it's another option that the op/others may not have been aware of.
  #12   Ban this user!
Old 01-18-2010, 06:45 PM
Your input is welcome and appreciated.
Large is relative. The travel is 12"x30". Tiny for those use to bridge mills. A monster compared to my current mini-mill. Most of my parts are small but the plan for this mill is to take in some paying jobs. I plan use a sliding DRO on the quill and read it directly..
Cheap HF router bits, just plain cheap? sonicwonder2000 DIY-CNC Router Table Machines 4 09-03-2009 09:18 PM
Why are these so cheap? daffelglass Stepper Motors and Drives 4 06-10-2009 10:10 AM
Cheap CNC, eh? ;) Zippi DIY-CNC Router Table Machines 4 09-11-2004 07:05 AM
How Cheap is Cheap??? HomeCNC DIY-CNC Router Table Machines 37 08-02-2004 11:01 PM
