Old 01-12-2010, 03:56 PM
porky118 is on a distinguished road
burny 2.8 led display dim
Is there a way to brighten up the display on the burny controller? I can barely see it to load or run programs.
Old 01-26-2010, 05:15 PM
Rick_0589 is on a distinguished road
I would suggest replacing the display. I know of know way to "brighten" it up. They are not expensive.
Old 01-27-2010, 02:32 PM
That was I was thinking also.
Thank you
Old 01-27-2010, 02:51 PM
The display just unplugs from a socket. Pay attention to how deep the old display was pluged into the socket. Try and install the new one the same depth. Just takes a little time because there are a lot of pins to align.
Good luck
Old 02-10-2010, 05:31 PM
FINDING LED BEFORE REMOVING
I haven't pulled out the old led display. I contacted the manufacturer and they said that the board just behind the buttons that has the display would need to be replaced. He quoted me around $3100.00 for the board. I couldn't believe it!!!!!! This is a machine at my work so I don't have all of the free time that I would like to work on it. I am responsible for all of the programming and some of the running of the machine so when it needs repair they have me check into things. If I pull out that board how do I get a new LED. I don't want the machine to be down so I would like to get a new display before removing it. Once the board is removed I have to re-enter all of the parameters again. This isn't something I want to do unless I have a part for it. Do you know of any resources for getting part numbers for a display. The manufacturer seemed more interested in selling a new card and front cover, not a display.
Thank you
BURNY 2.5 PLUS pftucker CNC Plasma and Waterjet Machines 5 05-31-2010 03:04 PM
Need Help!- Burny Parametric Programming Independent CNC CNC Plasma and Waterjet Machines 0 11-02-2009 02:26 PM
Burny 10 Independent CNC General CAM Discussion 0 11-01-2009 07:24 PM
anyone got burny 2.5 parts??? xjdubber CNC Plasma and Waterjet Machines 1 09-15-2009 07:11 AM
Burny comunications Jonp Machine Problems, Solutions , Wireless DNC, serial port 8 12-30-2006 09:35 PM
