Old 01-11-2010, 10:18 PM
triag is on a distinguished road
Running single phase motor using VFD
I plan to buy 1-phase to 3-phase VFD for spindle speed control for upcoming 3-phase motor.
Before that I would like to know is it possible to get 60 Hz single phase out from that VFD. I'm living in 50 Hz world but I have one single phase motor which requires 60 Hz to run correctly. Any specific wiring for this?
Old 01-11-2010, 11:07 PM
Al_The_Man's Avatar
You should be able to run the motor on 50hz if you can live with the reduction in rpm.
Old 01-12-2010, 12:56 AM
wdumay is on a distinguished road
A VFD is a Variable Frequency Drive , so the output can vary between 0 and a maximum frequency, generally 400Hz on a three phase motor,not on a one phase.
Old 01-12-2010, 08:42 AM
Actually I can run the motor with 50Hz but it gets very hot. I read about this before in this forum. It is because of something I didn't exactly understand, related to magnetism.
fitting a 110v or 220v single phase spindle motor on a 3 phase machine mwood3 Benchtop Machines 12 10-12-2009 09:53 PM
VFD for a single Phase motor!! Yepez Servo Motors and Drives 4 08-10-2009 06:53 PM
Newbie- ? about vm-16 or vm-17 running single phase? dccamp Milltronics 3 02-28-2009 04:01 PM
Can I convert single phase motor to three phase? Jim Estes Phase Converters and VFD 30 01-24-2009 02:41 AM
Need single phase motor help bob1112 General Electronics Discussion 8 02-24-2008 07:48 PM
