Results 1 to 4 of 4
Thread: Using DC speed controler for Power Supply
    Apr 2005
    I was wondering if it were possible to use a 90 v Dc speed controler as a power supply. I was thinking I could vary the speed setting to set voltage.
    I was looking at a surplus 90v 10amp unit. any comments, suggestions.
    this is my first post, I already submitted this once, but did not see it listed. sorry if I posted twice
    May 2004
    Welcome CNCDust. Many common DC speed controllers do not isolate their outputs from the AC input and could cause problems when connected to other devices... as in *very dangerous* problems. If you don't see a transformer, its likely it can't be used.
    JR
    Jan 2005
    Missouri
    I'm with JRoque on this. If there is no main power transformer on this, forget it. A lot of "controllers" take what they need off of the line and there is usually a lot of noise associated with it. Stick with the old tried and true linear supplies. If you can't get the current rating you need from one transformer, there is no shame in using 3 separate like transformers (one for each motor drive).
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Gold Member
    Dec 2004
    Newtown, CT, USA
    Quote Originally Posted by 2muchstuff
    You would be better off using three transformers in parallel. That way, they share the load and you gain from the fact that it is unlikely that all three motors will draw the peak current at the same time.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
  1. How does a power supply work.
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 07-27-2011, 10:40 AM
  2. CNC Controlled Spindle motor speed control
    By gregmary in forum General Electronics Discussion
    Last Post: 02-27-2009, 08:01 PM
  3. Need more power
    By mvaughn in forum General Electronics Discussion
    Last Post: 06-15-2005, 07:11 AM
  4. Motor calculations
    By jevs in forum General Electronics Discussion
    Last Post: 03-21-2005, 02:05 PM
  5. 5 Volt Power Supply Tripping
    By murphy625 in forum General Electronics Discussion
    Last Post: 02-27-2005, 10:05 PM
