Old 01-04-2010, 02:24 PM
Bird_E is on a distinguished road
Question Relay coil Question
Can I power 5 Volt relay coil with 24 volts with the proper series resistor?
I assume this will work. Should i be looking for a resistor that will reduce the current to what the realy coil is looking for? Or should I be looking at reducing the over all power (watts)
Example. 5volt relay coil @ 120 Ohms = 42ma or 210 milliwatts
If I was to drive the same coil from 24 volts should I be looking to limit the current to 42ma or the total power to about 200 milliwatts?
Current limited to .042 @ 24Volts
24 Volts / .042amps = .571 ohms - (120 coil resistance) = about 450 ohm resistor. But the power draw will be about 1 watt!!
Power limited to about 200 milliwatts:
.200 (watts) / 24vdc = about .008 milliamps (is that enough current??)
24/.008 = 3000 Ohms - (120 Ohm Coil Res) = 2.7K resistor.
How should I be looking at this?
Thanks!
Bob
Old 01-04-2010, 03:10 PM
Al_The_Man's Avatar
Only if it is a DC relay, you would need a 450ohm 1 watt resistor.
You are dropping 19v not 24v.
Not very efficient, how large a relay do you need, 24vdc relays are 10 a penny (well almost!).
embarassing relay wiring question endgrainguy General Electronics Discussion 5 01-14-2009 07:40 PM
solid state relay question aegfurn General Electronics Discussion 9 02-23-2007 09:09 PM
Question on lowering output voltage from a toroidal coil southernexplore General Electronics Discussion 1 07-26-2006 03:18 PM
cnc4pc relay board question Stuff-Builder General Electronics Discussion 14 03-17-2006 09:17 AM
Relay question shortbus General Electronics Discussion 3 04-26-2005 04:14 AM
