Old 01-01-2010, 10:38 PM
marzetti is on a distinguished road
Single axis motion without PC?
Does anyone know of an inexpensive way to drive a stepper for single axis positioning without using a PC? The application would be to position the fence on a panel saw using simple keypad input.
Old 01-02-2010, 01:26 AM
leggazoid is on a distinguished road
Here is one example, not cheap...
http://www.sherline.com/8800pg.htm
I have seen controller boards on ebay with a provision for jog buttons, maybe you could roll your own solution.
Old 01-02-2010, 02:07 AM
LZ1TWB's Avatar
LZ1TWB is on a distinguished road
Google "555 stepper generator" and you will see all sorts of schematics for this purpose. You will have to figure out a way to change the direction with the keys. Speed will be adjusted via a pot. Very simple circuit, one IC and a couple of passive elements.
Todor
Old 01-02-2010, 03:41 AM
gandalf1 is on a distinguished road
Step and direction generator
I used a variation of an LED flasher to generate steps from a 5 volt supply,
Direction from another switch on the supply and used a basic controller card kit for a bi polar motor that accepts step and direction signals, later I expande the same circuit to give variable speeds and also X,Y and Z outputs and with the printer cable connecting to the router can drive all three axes. Big problem is I cannot set it to travel any particular distance but as I only wanted to test the system for movement I did not worry about that. Total cost (for a single axis)was about $10 or maybe more depending on exchange rates at that time.
John (UK)
Old 01-02-2010, 04:31 AM
TOTALLYRC is on a distinguished road
Although this is for a rotary table it still generates step and direction outputs.
http://www.cnczone.com/forums/showthread.php?t=47007
Mike
Old 01-02-2010, 09:02 AM
Thanks for all the replies. The rotary table thread comes closest to what I'm looking for. What I need mostly is the logic circuit that would take my input from the keypad and tell the pulse generator what to do. Sorry if I can't make myself clear, I'm pretty new to all this.
Old 01-02-2010, 10:21 AM
Here is what I'm trying to achieve: http://www.tigerstop.com/BASIC.html
I can handle the mechanical design and could implement it using PC based CNC software but it seems like it would be overkill for such a simple application. All I really need is to move a fence to a given position. Could be it's not that simple and I need to stop being cheap and buy the system
Old 01-02-2010, 10:25 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
PICs, PICAXEs, Stamps, and Aruduinos, Oh my!
Look at the little microcontrollers like the rotab uses. They're real simple and easy to program. They won't be the absolutely cheapest, probably, though some are pretty cheap.
Cheers,
BW
PS Here is another rotab project:
http://www.homemodelenginemachinist....p?topic=7050.0
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
single axis control? jayty97 Stepper Motors and Drives 1 04-08-2009 07:05 AM
Single Rotary Positioning Axis RLMTS Mechanical Calculations/Engineering Design 6 01-11-2008 12:46 PM
Single rail for Y axis? jdholbrook DIY-CNC Router Table Machines 5 04-18-2006 07:29 AM
single axis controller robm7 Stepper Motors and Drives 4 10-22-2005 01:30 PM
Single Axis Positioner rcrabb General Electronics Discussion 4 10-30-2003 07:46 PM
