I thought I read this some where on the forum before but I can't find it now. I have a stepper with 6 wires (Unipolar), and I want to run it using my Xylotex Bipolar Driver, How do I figure out which wire go where?? Are two of the wires not used?? Thanks |
| I am also in process of doing same thing. I believe you are correct (two wires not used). If you ignore the center (common) wire, current rating has to be half of rated value (since resistance is double). If you ignore the other ends wire, current rating is as rated. I believe there's some info at Gecko site on this matter but let the CNC Guru confirm this. My question, running unipolar as bipolar means two phase are energise same time (more torque). Doesn't this means the heat to be dissipated is doubled? Is motor heating something I should worry about? Thanks
__________________ Stupid questions make me smarter... See how smart I've become at www.9w2bsr.com ;-P |
http://www.cnczone.com/showthread.ph...=stepper+wires
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| I don't think you can run a bi-polar motor with a unipolar drive. I'm running unipolar motors on a bi-polar drive. Using half winding. Done some testing and for me it runs better than full winding / half current. Regards Terry...... |
#11
| Next issue. I have a 4 wire Bipolar stepper motor. I have ordered pretty much everything I need to get it going. I do have one question. On all the documentation I have been reading it states "Power to the Motor". If you have only 4 wires, how do you get power to the motor? It was my assumption that the power was controlled via the controller card. I am a little confused. |
| St 6208 Dmos Driver For Bipolar Stepper Motor | gcamlibel | General Electronics Discussion | 7 | 01-25-2007 12:37 AM |
| Unipolar vs Bipolar | chuckknigh | DIY-CNC Router Table Machines | 17 | 10-29-2004 12:06 PM |
| Series Bipolar and parrallel bipolar? | CNCadmin | FAQ of CNC Machine building | 0 | 09-08-2004 08:17 AM |
| Fun with floppy stepper and driver | Konstantin | General Electronics Discussion | 5 | 03-08-2004 02:18 AM |
| Selecting stepper driver components... | fyffe555 | General Electronics Discussion | 0 | 09-26-2003 10:50 AM |
