Old 12-29-2009, 12:54 PM
keick is on a distinguished road
Unhappy Mechatronics and limit switches
I've gotten the mechatronics board to replace my twice failed xylotex board. But it doesn't have a 5V reference on the board. How am I supposed to wire in home and limit switches without a 5V source?
Has anyone done so with this controller?
Old 12-30-2009, 07:05 AM
vger's Avatar
vger is on a distinguished road
Which board? Is it the 3 axis, 4 axis, or 3 axis 10 amp??
If it is the basic 3 axis board, take a look at page 8 of this manual.
http://www.easy-cnc.com/web/download...3Axis(NEW).pdf
Steve
Old 12-30-2009, 01:02 PM
Those are for hardware disables, they turn the chips off which would be ok for some uses. They aren't something that the Mach3 can use for home switches.
The manufacturer did send me an email with a possible solution. If it works I'll post it up here. If someone else has done this I'd appreciate a response here as well since it isn't obvious.
Old 01-03-2010, 11:51 AM
Thumbs up
The unfortunate quick answer is tough-luck . You can wire the limit switches like any other board, since the voltage of the pins naturally floats high. But as anyone knows, that only works for very short wiring not running anywhere near your motor wires. They are also NOT optoisolated like the other pins .
So, what I did is buy a $5 worth of radioshack parts (5V regulator IC, and 2 capacitors). This let me get my 5V from the 24V power-supply and ran my own optoisolator board ($14 at futurelec).
The output side of the isolator I'm running the reference voltage off of pin 1 of the parallel port with Mach3 forcing it to high. The input side I'm running off of my regulator with the switches attached.
Result, $20 in hardware, and zero noise on my 20ft runs of switch wire running in parallel with the motors.
Tags
limit switches, mechatronics
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
CNC limit switches ptjw7 CNCzone Club House 5 01-21-2006 06:02 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
