This is one of those purchases I probably shouldn't have made but just couldn't pass up. It's an old Dumore grinder/buffer. Picture 4 below is a good overall shot of it. It just looks neat. My questions are on the rebuild of this thing. In picture 1 you'll see the overall shot of the bottom with some of the parts loosened. Picture 2 appears to be a resistor. On the end is written 140 and what appeared to be an Ohm symbol. I put a multimeter on it and indeed it measures 140 Ohms. Picture 3 seems to be a variable resistor. The speed switch had a wiper that contacted each of the copper pads and a wire was hardwired to the stud. Measuring the resistance from the stud to each of the pads I came up with (in Ohms): 0, 50, 80, 102, 128 and 10. Obviously there is a short somewhere on the last pad. Picture 6 and 7 show an "arm" that threads over the shaft and into the housing. Picture 8 seems to be some kind of oiler I'm assuming. You can also see it just below the shaft on the housing in picture 4. Sticking out of the threaded end is what appears to be a wick of some sort. Picture 9 is a shot of the screw that you take out to get to the brushes. The brushes seem to be in good shape and look to have a lot of life in them. Picture 10 is the motor with the cover removed. Oddly, there are no bearings anywhere. The shaft seems to ride in a velvet or cotton seal held on by the arm in picture 7. The oiler (???) in picture 8 contacts the bottom of the shaft. On to the questions! 1. Am I wasting my time here? The motor seems to spin freely by hand with no noise. 2. What type of speed control should I use to replace the big resistor and the variable resistor? Not sure what power pot or resistors I'd need. The name plate reads 115 volts, 250 watts, null load speed of 5000 rpm. Under "rating" it's hard to make out but I believe it says "1/6 30 MIN." Serial number is 2671 and type is D3. 3. The motor has 3 wires going to it however one of them was not hooked up to anything. Not sure if it should be. I plan on doing what I can to take the rust off of the external parts and plan to strip and repaint the housing and base. Any help or advice is appreciated. Upon further inspection I noticed the end of each housing has a brass bushing in it. I guess that's the reason for no bearings. |
| It looks OK to me. Just so long as the motor is not shorted to its own case that is. Any speed controller that can handle the motor will work. The motor only appears to draw 2 amps (I=W/E 2=250/115). You want a router speed controller style not an induction VFD. Motor should be series connected so 2 wires will run it. Maybe the disconnected wire is a safety ground? Only other advise I can give is don't go crazy oiling the motor. That is how I fried my last one here, over oiling it! Cleaning the commutator up on old motors can make them run nicer too. I use 400 grit wet or dry to just clean the copper. |
| VFDs are for squirrel cage induction motors. Universal motors aren't that. Universal motors are in items like corded drills, or vacuum cleaners, or Dremel moto tools. And use the same sorts of speed control. Oh yes, and routers too. You could use some kind of a huge rheostat, but a router style speed controller would be cheaper and easier today. Better too. A 250 watt rheostat would look like prop out of a Frankenstein film! Not an endorsement but here is one as an example: http://www.harborfreight.com/cpi/cta...emnumber=43060 |
| I'm a bit confused on the wiring here as well if anyone can help. The motor has 3 leads. I'll call them A, B, and C. Lead A goes to one of the brushes. Lead B goes to one of the brushes. From the brush with lead B another wire is soldered internally that goes to one end of the stator wiring. Lead C goes to the other end of the stator wiring. Seems odd that lead C wouldn't just be internally soldered to the first brush doesn't it? |
| We really need Al-the-Man to come in here for an expert opinion, but I think the wiring has been altered. From your description of the low wattage variable resistor bank I suspect the speed control was obtained by varying the voltage drop across the field. For this I think it would be wired parallel with the resistor bank in series with the field. I think you may be better off to clean it up and turn it into a lamp standard or something. 250 watts is very low powered for a grinder/buffer and I think the 1/6 30min indicates a low duty cycle.
| Yes, I was hoping Al might step in here. Actually I'm only planning on using it for very light aluminum deburring so I'm going to go ahead and rebuild it anyhow. I'm a sucker for antique machine tools with some style to them. |
| The restoration is coming along. I blasted everything with aluminum oxide to remove the old paint. Pictures 1 and 2 show the main motor after blasting. After that 2 coats of primer (pictures 3 and 4). Picture 5 shows the before and after on the oilers. Amazing what a little scotch brite and a lathe will do. Pictures 5, 6, and 7 show most of the major parts after being painted and cleaned up. I chucked the rotor in the lathe to clean and polish the shaft. I also cleaned up the copper pads where the brushes make contact. I was looking for some black satin paint but couldn't find any so went with the black "hammered" paint. I think it's looking good. I just need to wait for the paint to fully cure and then start reassembling it. Still stumped on the wiring. Al??? |
#10
| Hi Travis, Looking good. If nothing else it will be great for those delicate buffing jobs. My cousin was buffing some radiator brackets with a 3 hp buffer and the bracket caught in the wheel and tore it from his hands. He still has the scar. Mike
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
#11
| As Geof said, PM Al_The_Man and direct him here.
#12
| I think I understand the reason for the 3 wires now. 1 wire is common and goes to the commutator and the field. 1 wire goes to the field and the other wire goes to the commutator. I think it was done this way because so that the field (or commutator) could always get a constant voltage while the voltage was varied to the commutator (or field) by the pot. I'm just not sure whether to supply the constant voltage to the field or commutator or vice versa. |
| Sanford Surface Grinder Rebuild | Smrtman5 | General Metal Working Machines | 3 | 01-26-2010 07:33 PM |
| TNC 145 buffer battery help | Mike Woo | Bridgeport and Hardinge Mills | 1 | 08-17-2009 08:15 PM |
| HAAS VF2 DNC buffer problem | mmodeler | Haas Mills | 7 | 05-27-2009 06:11 PM |
| show z buffer | 1ctoolfool | Rhino 3D | 3 | 01-07-2009 02:56 AM |
| Fanuc O-M Buffer | inthezone | Fanuc | 7 | 07-24-2007 02:45 PM |
