Old 12-21-2009, 05:36 AM
Dale gribble is on a distinguished road
How do I wire a G203v disable pin
I've uploaded a jpeg of a basic wiring diagram for an Estop circuit I am planning. Can somebody have a look and see if this is correct, I'm using a cnc4pc C11 BB which I am wiring from the BB 5v output side through my Estop
button which is connected back to BB enable and to an input pin 10 on the BB.
So when I press the Estop, outputs are disabled on the BB and Mach also knows about it. I've added a 5v spst relay to connect a common signal to the drive terminal 7 disable pin. Will this circuit work?
Any information would be gratefully received
Regards
Dale
Name:	Estop wiring with Gecko drives disable relay.JPG‎
How to wire G203v disable connection with BB Estop circuit Dale gribble Gecko Drives 3 12-21-2009 06:56 AM
Need Help!- How do you disable SMI? SpeedsCustom LinuxCNC (formerly EMC2) 3 03-04-2009 03:22 PM
Need Help!- Disable FAPT F3T Pxt Fanuc 1 02-27-2008 08:28 PM
Disable switches swarfmacdaddy Gecko Drives 9 10-24-2007 02:28 AM
Disable with Mach belli Mach Plasma / Laser 3 07-14-2007 03:53 PM
