Hello I have this photo sensor : http://www.aleph-usa.com/os_detail_os-5202-2.asp It is said that it works on 5 v dc , but when I connect the 5v and GND leads to the supply and measure the voltage the voltmeter reads 0.9 volts and the output high voltage is also the same. and when I disconnect the 5v supply leads and measure the voltage across them it reads 5v normally. I tried the same thing to phototransistors EE-SX3009-P1 (omron) and I got the same result (I attached the datasheet of the EE-SX3009-P1). Could anyone tell me what is the problem and is this normal ?? |
| Did you connect it up as per the suggested diagram? A suitable diode resistor and a load resistor in the collector of the transistor? The Omrom device only needs a load resistor, the diode resistor is internal. The supply on the Omrom is 10v and up to a 28vdc load voltage can be used. Al.
| G96 Not Working How it Should on T32 | mbpp | Mazak, Mitsubishi, Mazatrol | 0 | 06-13-2009 08:53 AM |
| problem with working with solidworks files | tnik | Surfcam | 7 | 09-04-2008 06:46 PM |
| G76 not working | cadman@teluspla | G-Code Programing | 3 | 08-11-2008 03:47 PM |
| THC-300 not working | bad-rat-57 | CNC Plasma and Waterjet Machines | 1 | 07-30-2008 11:13 PM |
| problem with BP series 1 spindle not working | zoqdi | Bridgeport and Hardinge Mills | 0 | 02-06-2007 03:04 PM |
