Old 03-27-2005, 10:51 AM
edbo68 is on a distinguished road
Linear Or Switching Power Supply
What woulod be better to use a Linear Power Supply or a Switching Power supply for stepper motor control?
Wouldn't the Switching power supply be more efficant and be able to put out a continuously steady current and voltage as the load increases compared to the linear power supply or am I still buggin on dope I did in the eight grade?
Would the PWM switching cause problems with the stepper control?
I may be answereing my own question on this one but I would think not, as most printers use switching power supplies. But I would appreciate some feed back on this anyway.
It's amazing how much more thinking I do when I'm on the crapper!
Ed-
Old 03-27-2005, 11:06 AM
Gold Member
lerman is on a distinguished road
IMHO, a switching supply would be lower cost, lower weight, higher efficiency, better in just about every way.
It would also require more time to design and debug. It would be harder to build in single quantity, and possibly more expensive in single quantity, depending on how good a scrounger you were and how you valued your labor.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 03-27-2005, 01:19 PM
H500 is on a distinguished road
A switching supply has many theoretical advantages, but in practice a linear supply is superior for stepper motor control, for the following reasons:
1. Better stepper controls use PWM to limit the current. This produce lots of electrical noise. Many switching supplies will go beserk unless you design additional filters.
2. It is difficult to find cheap surplus switcher capable of putting out the 30-70 volts required by high performance systems. The cheapest switcher is a computer PS, but they're only 12V, which is not nearly enough.
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 09:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 03:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 09:05 PM
Is this power supply rating adequate? jerryrigge General Electronics Discussion 3 11-25-2004 10:06 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 10:36 PM
