Old 11-17-2009, 02:14 AM
Brenck is on a distinguished road
Can I fuse a DC power supply?
Hi all,
I want to know can I fuse a DC power supply? After the rectifier and capacitors?
It would be like... Transformer-rectifier-capacitors-fuse...
Or maybe Transformer-rectifier-fuse-capacitors...
Do I just use regular fuses? Or is there a DC kind of fuse?
Old 11-17-2009, 03:20 AM
jeffery71 is on a distinguished road
Yes you can and should fuse the dc power supply
Transformer- Rectifier- Capacetors- Fuse
The fuse should be on the + wire
You can use the regular glass tube type fuses..
It should be a fast blow type.
Jeff T.
http://www.3dcarvestudio.com
Old 11-17-2009, 08:15 AM
Al_The_Man's Avatar
The common way is in the AC side of the bridge.
Old 11-17-2009, 08:34 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
See page 10:
http://geckodrive.com/upload/Step_motor_basics.pdf
CR.
Old 11-17-2009, 09:01 AM
I'm not an expert thats for sure. But the idea of using a fuse is to protect the drive/motor. If you are using more than 1 drive/motor from the same power supply I can't see how having 1 fuse on the ac side of the rectifier is going to proctect the drive's/motor's
Putting a fuse for each drive/motor on the dc side you protect each Drive/motor with its own properly sized fuse.
Jeff T.
Old 11-17-2009, 10:02 AM
Its actually for a 12VDC power supply for the logic of a stepper drive, the problem is that this 12vdc 3.5A I have it one of those that you buy it already built and the transformer inside there is no way to connect any wire before the diodes...
I always used on the AC side and it actually protects your driver, I had a short circuit on the driver 2 times, one when I was adjusting the trimpot on the L297 based driver and the other one I dunno what happened but the fuse blow and after I change it nothing was damaged.
Is it just a regular fuse to use when using on DC?
Old 11-18-2009, 08:32 AM
Just the regular glass cyclinder type fuses work fine http://www.allelectronics.com/make-a...5/Fuses/1.html
Should have a fuse for each drive... Sence its only a 3.5 amp supply I'm guessing your only using it to power 1 drive so doesn't matter were you put the fuse. But if you were trying to power more than 1 drive it should be 1 fuse for each drive and would need to be on the dc side of things after the capaciter.
Jeff T.
Old 11-18-2009, 08:55 AM
Thank you all for the replies.
I used those glass fuses it worked fine
Tags
fuse
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
Fuse for 5010 power supply bd007 Automation Technology Products 0 04-11-2009 03:13 PM
Fanuc Power Supply Internal Fuse Blown hrhoward Fanuc 1 01-07-2009 03:42 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
Power supply fuse sizing question kevincnc General Electronics Discussion 3 03-25-2005 03:09 PM
