Old 11-12-2009, 04:58 AM
cjchands is on a distinguished road
Purpose of Capacitor connect with Spindle Motor?
I see that there are 3 capacitors connect to Magnetic Relay in parallel with R-S, S-T, T-R terminals.
The unit is for turning spindle motor clockwise or counter clockwise thru the hand switch.
My question is WHY would you need these capacitor connect in parallel for?
Back Voltage when suddenly switch Clockwise to Counterclockwise?
Thank you
Jeff C.
Old 11-12-2009, 08:53 AM
Al_The_Man's Avatar
Are they capacitors or R/C back emf snubbers? these can also come in a single unit designed to hook across three phases.
Old 11-13-2009, 01:39 AM
Hi Al,
You are right!! It is R-C Network.
The part is RG1676-24 (1000V, 10W)
http://www.galco.com/techdoc/elcu/rg1676-16_app.pdf
I guess it is use for Back EMF in case switching FWD/REV right away to suppress surge Voltage.
According to the brochure..it is also eliminate noise too?
Would this noise be connected to MOVEMENT of X-Y-Z axis as well??
What if......
If you turn spindle CW and wait until stop, then turn CCW...I guess you don't need R-C network??
Thanks again for your helpful comments.
Jeff
Old 11-13-2009, 10:05 AM
Al_The_Man's Avatar
Applying power to an induction motor while it is still turning in the opposite direction is called a plug stop.
Often these snubbers where fitted to this kind of application, now it is common to see the R/C network added to 3 phase reactors in VFD applications.
PSC motor capacitor trouble ericaustin General Electronics Discussion 3 07-24-2008 07:24 PM
Connect 200V servo motor to 400V drive interflexo Servo Motors and Drives 0 04-15-2008 01:34 PM
Non-polarized start motor capacitor in DC jc40 General Electronics Discussion 2 11-17-2007 10:37 AM
How to connect Step motor to PC parallel port manoj2s Stepper Motors and Drives 3 06-09-2007 10:20 AM
Need help to connect motor to controller ezland00 DIY-CNC Router Table Machines 25 11-16-2003 11:08 AM
