Old 03-20-2005, 03:18 PM
DAB_Design is on a distinguished road
Talking Does size really matter?
I know I"m going to have to eventually rewire my control box. And was curious as to whether or not size matters as far as wire guage. I know going too small would be a problem. But what about using a size that is larger than what I'm using now?
For example, I have what I believe 20 or 22 guage wire running to my encoders. Would it be ok to use 18awg? When working with small wires (like 22awg), my fat fingers have a hell of a time getting them where they need to go, and keeping them there while I solder, crimp, or whatever means I'm using to connect them.
Old 03-20-2005, 03:54 PM
TigerPilot's Avatar
TigerPilot is on a distinguished road
Rule of thumb says you can't go smaller but you can go bigger. We are working with low voltage. A small wire will have a higher voltage drop on it because of the higher current, and therefore less voltage getting to the load, than a bigger wire. A small wire will get warmer then a bigger one again because of the higher current. We are using small wires in a computer because it is just communication and the currant is in the low milliamps.
All in all, give your fat fingers a break and go ahead with the 18awg. :-)
Yoram
Old 03-20-2005, 04:27 PM
Excellent! Thanks.
Ball Screws and machine size? swiftden DIY-CNC Router Table Machines 2 02-03-2005 04:02 PM
for engraving pcb which is a good thread size for the lead screw? NickLatech DIY-CNC Router Table Machines 11 01-17-2005 08:37 PM
Ballscrew size -vs- project size Alan T. CNC Machining Centers 4 10-18-2004 08:53 PM
size of 4th axis drive converterk AjaxCNC Control Products 10 06-07-2004 10:01 AM
What size steppers? cnczoner General Metal Working Machines 6 05-18-2004 11:32 PM
