Old 11-02-2009, 12:46 PM
fusiontech357 is on a distinguished road
help with power supply
i am a nubie in the cnc world and need a bit of help in choosing the power supply for my system . The drivers im looking at are 2 phase 3amp drivers im thinking of adding them on to my seig X2 so ill be running 3. do i need a power supply that is rated amps X the number of drivers or would 3 amps be enough????? p.s the working voltage is 24volts as well that i know has to stay the same , just a bit lost in the amprage.. any help would be greatly appreciated. thank you .
Old 11-02-2009, 01:10 PM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Hi FT. Welcome to the Zone!
All of your questions are answered here:
http://www.cnczone.com/forums/showthread.php?t=78713.#3
CR.
Old 11-02-2009, 02:48 PM
thank you so much crevice reamer , that was a great help , now all i have to do is use those formula's . and ill be set .
Old 11-07-2009, 01:47 AM
lol ok so i found a dual power supply 24v at 3amps and 5v at 8amps . i am wondering , since i dont know anything about electricity will the 8 amps on the 5v side for the breakout board be to much or will the system only use whats needed???? really dont want to have to buy a new breakout board.. anyone have this problem?
Old 11-07-2009, 08:35 AM
You can always have extra Amp capacity and it won't hurt anything. The BOB will just draw what it needs--But you wouldn't want to have a PSU rated for LESS Amps than the BOB needed.
BTW: There is no better driver for X2 than the G540. This is what I recommend:
$289 G540 http://geckodrive.com/product.aspx?c=3&i=14469
$147 Three $49 KL23H2100-35-4B 381 oz motors for X, Y & Z
$060 One KL-350-48 48V/7.3A power supply.
$010 Estop switch
$007 3 Home switches
$009 Straight thru parallel computer cable.
$522
http://kelinginc.net/index.html
CR.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Need help for a 12v-18A /5V power supply Niggo General Electronics Discussion 11 10-06-2006 12:11 AM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
Power supply help osdhillon General Electronics Discussion 12 06-01-2005 01:32 PM
