Old 10-23-2009, 09:36 PM
guy2b1's Avatar
guy2b1 is on a distinguished road
How Mach3 can Turn On/Off my Router during operation?
I would like to ask how Mach3 can control the power of my Router/Trimmer power tool when to turn on and off. What pin assignment in the printer port will I assign my Router/Trimmer as my CNC Spindle? Any wiring diagram that I can follow so that my Router/Trimmer Spindle can automatically turn on and off during CNC Operation? Im a newbie to electronic stuffs and very scared to blow things up, but I can follow instructions on how to wire, please help
Old 10-24-2009, 04:07 AM
guy2b1's Avatar
bump
Old 10-24-2009, 07:40 AM
ger21's Avatar
In ports and pins, assign any output pin to an output, then go to the spindle tab and assign that output to M3 - Spindle on CW. COnnect the output pin to a relay and M3 in the g-code will turn it on, M5 will turn it off. You'll may want to buy a relay board like this.
http://www.cnc4pc.com/Store/osc/prod...roducts_id=132
Old 10-24-2009, 09:42 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Here's a relay for $5 that will work with 5V DC from BOB and up to 25A AC to router.
http://shop.ebay.com/forcem/m.html?_...&_trksid=p4340
Better hurry though--it might be the last one he has.
CR.
ETA: Oops. He might not ship to Philappines.
Old 10-24-2009, 09:54 PM
guy2b1's Avatar
Thank you very much for your reply. I am lost assigning pin numbers for my spindle I do not know which is pin inputs and outputs im a little scared to blow things if somethings go wrong. I remember my current setup is:
Pin 2 to 9 - for my 4 axis stepper motors
Pin 15 - for Probe AutoZero function
Pin 21 to 25 - for grounding
So which pin no. in my printer port should I assign for my Spindle to automatically turn on/off by Mach3? I have a Router/Trimmer power tool with 530 Watts power 35,000rpm and probably I will upgrade to 2HP Router sometime.
Maybe sometime im adding to 2 additional axis for B and C to slave, which pin no. in printer port should I assign for my additional 2 stepper motors just in case?
Old 10-24-2009, 10:25 PM
Al_The_Man's Avatar
Search for 2n7000 here for driving it direct from the port.
http://www.cnczone.com/forums/showth...ghlight=2n7000
Old 10-24-2009, 11:32 PM
guy2b1's Avatar
Sorry I forgot to mention the relay Im thinking which pin number in printer port will I connect the relay, then relay connecting to my Trimmer/Router power tool? Any wiring diagram for me to follow? Will buy the needed relay soon for my 530Watts 35,000rpm power tool. Or if I can buy a relay ready for 2HorsePower router in case I change my trimmer
Old 10-25-2009, 09:30 AM
Why aren't you using a breakout board? What are the Amp requirements for your routers?
http://www.cnc4pc.com/Store/osc/prod...products_id=45
CR.
Old 10-26-2009, 05:26 AM
guy2b1's Avatar
What type of relay?
No I do not use breakout board as it is not available to purchase locally here. My setup is connected directly to printer port pins. Currently Im using a small router/trimmer power tool. The label written at the back of my router/trimmer is 220-230V 2.4A 50-60Hz 530W 35000rpm. Can I attach a relay directly to my printer port so that Mach3 can turn on/off automatically? What type of relay should I buy? Im not an electronics expert but I can follow instructions carefully as I am very scared to electric shocks.
If I will buy a powerful router with 2 Horsepower in the future to upgrade, what type or kind of relay should I buy so that I can use my present small router/trimmer compatible ready for 2 horsepower power tool?
Tags
mach3, pin, router, spindle, trimmer
Set Home on Mach3 Turn scot1972 Mach Lathe 1 03-12-2008 01:46 AM
Help!! Using Formulae to turn ovals with Mach3 rajiv.tctech General CNC (Mill and Lathe) Control Software (NC) 2 03-11-2008 10:23 PM
G-code manual for Mach3 turn? Green0 Mach Lathe 4 06-25-2007 07:57 PM
At last! First CNC Router in operation novacustard DIY-CNC Router Table Machines 3 11-30-2006 07:20 AM
At last! First CNC Router in operation CNCadmin DIY-CNC Router Table Machines 0 11-27-2006 10:00 AM
