| For capacity, you either need a capacitor meter or use an R/C time circuit with a sensitive volt meter. But for opens and short circuits, a simple ohmmeter will work. Shorts are obvious, a rough guide to open and capacity is to place the ohm meter across the cap and watch the charge rate, (the meter puts out a voltage on ohms), when it stops, reverse the leads, you will see a discharge in the opposite polarity, the time taken to charge and discharge is a rough indication of capacity, especially if you compare it to a known good cap. Al.
| Good info Al. I used to check for leakage by charging the cap to a known voltage level, then wait for a bit of time and check the voltage. If the cap was leaky, the voltage would be lower, sometimes much lower than the charged value. Steve |
| capacitors | cueshark | General Electronics Discussion | 5 | 05-15-2007 11:40 PM |
| capacitors | cueshark | General Electronics Discussion | 3 | 04-22-2007 10:50 AM |
| capacitors | mmachining | General Electronics Discussion | 2 | 08-07-2006 08:42 PM |
| Testing Capacitors | aggie_67 | General Electronics Discussion | 3 | 08-04-2006 08:46 PM |
| Capacitors | Don C | Gecko Drives | 3 | 05-17-2004 11:39 AM |
