Old 10-19-2009, 07:03 AM
86meesta2 is on a distinguished road
Expresscard to Parallel?
As with almost all newer laptops, my Dell E1505 doesn't have a parallel port. I've been reading and now know that a usb to parallel adaptor won't work. Some have said PC cards will. I have an 34mm expresscard slot, and have found cards like:
http://cgi.ebay.com/New-1-Parallel-P...item5883d6e354
Is an expresscard just like a PC card?
Thanks!
Old 10-19-2009, 03:09 PM
keebler303 is on a distinguished road
I have no idea if a card like that will work. Are you using mach3? If so, have you looked at a smooth stepper?
http://www.warp9td.com/
Just another option to consider.
Good Luck
Matt
Old 10-19-2009, 06:59 PM
Yeah I checked out the smooth steppers previously but they're out of stock and I wanted to get this machine going within two weeks. I'm using mach2, but either way I just bought a cheap desktop with a real parallel port to dedicate to it, so I guess the expresscard mystery will remain!
Aspire one+USB to ExpressCard+ExpressCard EPP Parallel Port jafc76 Mach Software (ArtSoft software) 4 06-28-2009 09:05 PM
parallel port or parallel universe bruno34 Taig Mills & Lathes 5 04-15-2009 10:58 AM
ExpressCard Parallel adapter? GMTool General CNC (Mill and Lathe) Control Software (NC) 1 03-24-2008 11:41 PM
Need Help!- ExpressCard Parallel Port for notebooks? jeffmorris DIY-CNC Router Table Machines 2 03-20-2008 07:10 PM
(425 oz in) @ only 4.7V and 2.8A parallel? Oldmanandhistoy Stepper Motors and Drives 13 02-17-2007 02:05 PM
